How much $ do you have in your rebuild?
I am adding up all of my engine rebuild receipts and cannot believe how much money I have thrown on this rebuild. I have tried to save wherever I could and I do the work myself. My total is north of $8K to rebuild a 78 SC engine into 3.2. This amount includes M&K muffler and SSIs and staying with the CIS system. Anyone else want to share their secret?
Do not feel bad, way too much here. I am even selling stuff that I love to pay for future improvements. Custom mountain bikes and road bikes, my 72 911t roller, other odd and ends. All in the endeavor to make an out of date air cooled motor more powerful. At the end of the day I probably could have purchased a gt3 motor and put it in the car and called it a day. Wish I had thought of that before.
That will teach you not to add up your receipts. :)
All my receipts are kept in a secret tin in the garage marked 'Broken Parts Bin'... *laugh* I don't dare add those up... If she who holds the purse strings found out I'd be installing hard wood floors and other honey-dos instead of working on my car :( for a year...
I think i might have about 3-4k into it as an stock rebuild... but, I've been part collecting for a year. best regards, michael |
Re: How much $ do you have in your rebuild?
7k in the engine...so far now add an extra $2300 for the transmission that was diagnosed last week. Whenever my wife needs anything done around the house, or the dishes done, she just brings up the rebuild.
3.2 L top-end including new exhaust valves, valve guids/seals/keepers, 964 cam regrind, new rocker shafts, re-bushing rocker arms, and complete engine re-seal: $2200 in parts/labor. That includes a few while you're in theres like ref/speed/cyl head temp sensors. Plus $850 for a trans rebuild. So, just a hair over $3K for everything.
I did everything but the machining. This is my 2nd 911 rebuild, so I learned how to save this time. :D |
Jay can you offer some tips on what you did differently vs. your first rebuild to save money?
My totals are similar to Jay's. I have my '82SC engine apart and waiting for my heads and cams to come back. I have done everything myself except the machining. Reconditioning the heads, regrinding the cams (964) and reconditioning the rockers will come in at ~$1000. Consumables for the rebuild (i.e. bearings, gaskets, head studs...) will be ~$1000. I picked up a set of engine tin (mine was pretty rusted) for $100, a muffler for $50, crossover pipe $30. About $125 in parts to rebuild the CIS.
All in all, I imagine I will be somewhere around $3K. I don't think I cut any corners, but I kept things pretty much stock. Geoff |
I guess my shopping list is the biggest so far then:
Motor: New P&C's from EBS JE 10:5:1 New bearings New CAM tower on the passenger side New spray bars Complete powder coat of all tin, fan, anything else attached to the engine for that matter Crank work Rod work New to me SSI's new stainless muffler Oil lines Timing chains reconditioned rockers 964 cam regrind (thanks Camgrinder!) Final assembly labor (I travel just about every week, so I can't get it done) Transaxel: New sliders dogs and syncros on 1 and 3 and 4 New shift forks New shift guides New bearings in case Professional labor I'll do the final assembley including installing the covers, shroud and injection. I'll also mate the transmission and install the motor. |
I have three rebuilds going on at the moment: 3.0 turbo project, 2.7 race engine, and 2.2. If I start adding, I will have to slit my wrists.
Pat |
I stopped counting after NOS Mahle 92mm P&Cs :)
AM |
i've done a stock rebuild/re-seal and ring on a 2.7
taken that out to 95mm P&C's so it was a 3L, flowed the head and added SSI's.. sold that 100mm Mahle P&C's 3.3L turbo case and oil pump machine shop work cariallo rods raceware rod bolts &studs ported heads (3.2L base) Electromotive crank fire ignition dual pluggs, 6 coils front mount oil cooler mod s cams 46mm webers B&B headers, sold them, European racing headers. ceramic coating M&K muffler powder coating this that and the other thing + labour....= 5 digit ouch.... edit you'll also see i have sold off and am selling many of my spare parts.... this isn't because i don't like them |
Andrew
Since I did stop counting, I may need the Zenith kits after tax day. PM me if they don't sell on Ebay! Pat |
Interesting thread,
I don't add up my receipts but I do hide them from the wife...just kidding. You really got to love these cars because it's difficult getting your money back if you sell. For me, selling is not the objective...I love these cars! If your curious, I have a 3.2L Euro in a 76 Targa. I'm almost finished with this 2.5 year long project. I rebuilt and replaced just about everything, most of the work is done by me to save money. I even learned how to powder coat. At this point I'm about $5000.00 invested. Regards, Alex http://forums.pelicanparts.com/uploa...1174887176.jpg http://forums.pelicanparts.com/uploa...1174887204.jpg |
Mine has a more traditional look. I would like to try doing a little extra powder coating with the next one.
Cheers, Michelhttp://forums.pelicanparts.com/uploa...1174925459.jpg http://forums.pelicanparts.com/uploa...1174925491.jpg |
Once I broke $10k I stopped counting. I suspect it will end up somewhere around $13-15k.
targa went up to 13-14K ish... euro's...
Reading this thread it looks like those that go with different P/Cs than they had spent much much more. To be expected, but the amounts are beyond just the parts...
if you are going to go... go big ;) -m |
The heads are not powder coated, I should have mentioned it before posting the pictures. The black treatment is a heat dissipating thin layer of paint to help keep the heads cool. I used various treatments in areas like my piston domes (ceramic coated), dry lube on piston skirts, oil release below pistons, dry lube on wrist pins and I also treated my valve surfaces with ceramic and stems with dry lube film.
Regards, Alex |
thx for the clarification , never seen that..
About $14,000. I did all the work tearing it down and rebuilding it. This includes a new turbo, P&C's, new 964 cams, machine work, and some powder coating. All the shipping and small stuff adds up too.
After you buy a set of these everything else is pocket change (because that is all you have left).
http://forums.pelicanparts.com/uploa...1175045710.jpg |
This thread is making me feel better :-) Hope my engine runs.
Michel 1976 911S targa |
You guys can do the math...
3.4 10.5:1 Twin plug DC44 cams (108 lobe centers on new billets) 12 new valves new rocker arms Race springs Ti retainers 48mm Jenvey throttles Microtech ecu and digital dash ARP rod bolt ARP head studs Boat tailed case Balanced B&B headers M&K GT3 Style muffler MSD coils Elephant front mount cooler (Setrab) http://forums.pelicanparts.com/uploa...1175056756.jpg http://forums.pelicanparts.com/uploa...1175056781.jpg Bobs throttles take the cake though.... you should ask him about the rest of the car!! :0 Cheers |
When I bought my 70 S Coupe in 1989, the engine was running (well) but had low oil pressure, about 20 psi max, dropping to almost 0 at idle. It was all original with about 115,000 miles at that time.
It was driven for only about one month, then parked in my garage until mid-1995 when I started the rebuild. All of the MFI was rebuilt by Norbert Eberhart & Gus Pfister Added new SSI exhaust Replaced one head and one cam tower resurfaced 2 cams New mahle 2,2 S P/Cs New valves, springs, rockers, shafts, and assoc hardware New Int. shaft, cam chains, sprockets, ramps, etc New Carrera tensioners New flywheel New Alternator Bearings & gaskets - all, of course Machine work on cases for piston squirters, oil relief update Machine heads New oil pump new oil cooler on engine new oil thermostat, engine New ignition parts, all except Dist body & Bosch CD Powder coat air cleaner, all engine tin, rear engine mount plate So there is virtually nothing old in my engine except the crank, rods, and cases now. Total cost in 1999 dollars was pretty close to 20 big ones. It does run like a dream & the original MFI purrs like a kitten. I am happy, but I would hate to have to do the same today...:eek: |
Should have posted a pic of the final product.
http://forums.pelicanparts.com/uploa...1175129105.jpg http://forums.pelicanparts.com/uploa...1175129124.jpg |
| All times are GMT -8. The time now is 10:00 AM. |
