Eye of the Toiger
matty74's Avatar
Looking to buy a 3.0 sc motor
Looking to buy a 3.0 sc motor for my 74, what type of motor should I go for pre 78 or 78- 82, running preferably but aim is to rebuild a long block would be OK as I have webbers exhaust etc..
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 03-26-2007, 11:06 PM
drag racing the short bus
dd74's Avatar
78-79 have better (larger diameter) heads and wider intakes, but compression only at 8.5:1. '80-'83 have smaller diameter heads and intakes, but higher compression (8.6:1 for the '80, and 9.3:1 for the '81-'83). The '83 has a different and possibly more robust block, which was the basis for the 3.2, IIRC.
Both variants of the 3.0 are very good engines. Either should work well with Webers.
The Terror of Tiny Town
Old 03-26-2007, 11:45 PM
