-   -   early 2.0 intermediate shaft setup (http://forums.pelicanparts.com/911-engine-rebuilding-forum/338237-early-2-0-intermediate-shaft-setup.html)
edbaus 03-28-2007 09:52 AM
Hi,
Are the shims still avalible, or do you use a stackup of gaskets. What is the current proceedure on this.
What is the clearance supposed to be.
Ed
andrew15 03-28-2007 09:53 AM
Our host actually sells the shims. The correct procedure for setup can be found in the early factory manuals
Regards,
Andrew M
edbaus 03-28-2007 12:20 PM
Andrew,
Great thanks. I can not see, however, where the shims are on this site. Spent about a half an hour looking. If you could post a link I would appreciate it.
I called my local p-car dealer (Stoddard) they said that they were discontinued.
This is a race motor that I have built before. Last time I assembled it I used a stackup of several gaskets instead of shims because I was led to believe this is the current procedure since the shims have become un-avaliable.
Ed
304065 03-28-2007 12:26 PM
901 105 198 04 supercede to 930 195 198 01 gasket $1.75
901 105 162 02 shim 0,20 mm availabe, $38.50!
Look here: http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait= N&make=POR&model=911E&section=ENGman&page=5&bookma rk=15&part_number=901-105-162-02-OEM
edbaus 03-28-2007 01:22 PM
Hey, there they are.
So, why would I not just use a stackup of gaskets?
I think I used 3 gaskets last time.
Ed
andrew15 03-28-2007 04:42 PM
Because gaskets compress and lose the precise nature of this measurement. Pelican has a whole variety of the shim thicknesses under the Engine heading in the new parts area - look under crankcase and related parts.
AM
shbop 03-29-2007 07:14 AM
I ordered a specific shim from Henry @ Supertech. I didn't like the idea of trying to guess the crushed height.
