What would Henry Schmidt do......
So....I pulled then engine on my cream puff 82 SC (2nd owner, 65k miles) to reseal it. (Had a gusher from driver side cam tower). When I pulled the valve covers I found 2 head studs in there.... :eek:
So....my question is what can you do to a 3L to improve performance? Change outP & C's to allow for bigger cams? Stroke it? I have a set of 40 PMO's to finish this project... |
Does the car need to pass smog tests?
Is it going to be a street car? Whats your budget? A properly-cammed, 3.2 litre motor with PMO's and a proper exhaust can be made to run VERY well. :) Twin-ignition would be a big plus. |
I'm not sure about the rest...but I guarantee that Henry would use Supertec head studs.
Well Steve...you pretty much hit the nail on the head for what I was considering...we do get 93 octane down here in Floriduh.....
But I think the cost would put me back to another 3.6 conversion....not that there's anything wrong with that......;) Fint, the Supertecs are definitely on my list...:D |
If your budget is like mine, here's what I would do.
With 65K on the engine you can count on reusing the pistons and cylinders. Hoping they are Mahle Nikasil I would put valve pockets in your 9.3 :1 cis pistons, DC40 cams w/John's springs, port intakes to 39mm and install your 40mm PMOs and SSI exhaust and M&K muffler. 240+ hp Head studs are optional but I appreciate the plug. With an engine like this you could just replace the Delivar with steel studs. Now if you have a budget like the Pentagon, 3.2 short stoke, Carrillo rods, ported to 40mm, ty valves, DC80 cam w/Supertec valve springs and ty retainers, Supertec twin plug, Supertec stainless steel exhaust, M&K muffler, Aluminum flywheel, custom built MFI and of course Supertec head studs. 320+ hp. http://forums.pelicanparts.com/uploa...1175189689.jpg |
Henry, what else can be said other than...
"you are THE picaso of porsche 911 engines" Bob |
Ask and ye shall receive...Thanks, Henry....
I need to call my congressman and see if he can get me in that mass appropriations bill.....:D |
what are the cost estimates?
Henry,
Can you provide any general estimates on the total costs for the two engines? Sourced from you? thanks much marlin |
Re: What would Henry Schmidt do......
www.jbracing.com |
Re: what are the cost estimates?
cool options and thanks for the plug as well henry. gotts get rolling on thise ss headers see ya!
| All times are GMT -8. The time now is 09:30 PM. |
