Eye of the Toiger
matty74's Avatar
Is a 2.7 CIS engine with 7R Case 90mm?
Is a 2.7 CIS engine with 7R Case 90mm cyliner diameter?
Can I use 92mm on a 7R case?
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 04-19-2007, 08:03 PM
Perhaps I can help,.........
All 2.7 engines use 90mm cylinders. 2.8 engines use 92mm cylinders.
Both have 97mm spigot diameters and are interchangeable so no machine work is necessary to install 92's instead of 90mm ones.
If you use the Mahle 92mm RSR ones, be aware that those were designed for the RSR heads which have much bigger chambers than 2.7 heads have and this results in a very high CR unless some modifications are made.
I always recommend twin-ignition for 92mm engines,....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-19-2007, 08:09 PM
Eye of the Toiger
matty74's Avatar
Has anyone used the cylinders? QSC?
http://cgi.ebay.com/ebaymotors/Porsche-911-90mm-Cylinder-JE-Piston-Kit_W0QQitemZ260109802080QQihZ016QQcategoryZ33623Q QrdZ1QQssPageNameZWD1VQQcmdZViewItem
Old 04-19-2007, 08:16 PM
