Eye of the Toiger
matty74's Avatar
What is the Diff MFI 2.4 S Vs T
What is the Difference between MFI 2.4 from a T model vs an S model engine, what would I need to do to it to hot it up for a
2.7 S engine?
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 04-10-2007, 05:51 PM
The only differences that I know of are the different space cam in the pump, bigger Throttle bodies, and bigger trumpets. Yes you can modify the T system but it gets expensive because of the mods or buying the S parts. Henry is guite the MFI guru. He may be able to do the mods for you.
-Andy
Old 04-10-2007, 10:50 PM
