-   -   901/06 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/340659-901-06-a.html)
gregk1 04-11-2007 10:08 AM
901/06
i have a 67 901/06 with cast iron cylinders is this still 2.0 or built to 2.2 ???? and what cams came in the 901/06 engine any help would be great thanks>>>>>>> Greg
304065 04-11-2007 11:47 AM
Greg,
What do the cylinders look like? Can you post a photo? Cast-iron fins didn't come in until 1968 with the 911T, so they could be two-liter, or they could be 84mm from a 2,2 or 2,4 E. But it's hard to tell without photos.
The 901/06 had a reduced performance camshaft called the 911L cam. Its specifications are:
I opens 20 BTDC
I closes 34 ABDC
E opens 40 BBDC
E closes 6 ATDC
Compare that with the Solex from the 901/01 and 901/05, which is
I opens 29 BTDC
I closes 39 ABDC
E opens 39 BBDC
E closes 19 ATDC
and you can see it's a reduced-performance cam. It was intended to maintain the 901/06 at 130 HP even though the later "SSI-style" heat exchangers, which were introduced for the 911S, would have bumped power to 140HP. This narrowing of the power difference was unacceptable to the marketing department, hence the change to the cam.
YTNUKLR 04-11-2007 02:45 PM
Photos will tell if it has 80mm or 84mm cylinders. Cast-iron fins are from the '68+ 911T, but these cylinders fit right on to a 2.0L with no mods.
gregk1 04-12-2007 08:02 PM
http://forums.pelicanparts.com/uploa...1176433232.jpg http://forums.pelicanparts.com/uploa...1176433277.jpg hear are some pictures
911quest 04-12-2007 08:22 PM
If any thing else it has an aluminum case very sought after
It has cast iron cyl. "T" P/C
YTNUKLR 04-12-2007 11:50 PM
Greg, you have a 2.2 (84mm) set of P/C on there .
gregk1 04-13-2007 06:19 AM
so if someone put 2.2 P&C's then who knows what it may have for cams just might have to rebuild it insted of parting it out hmmm what to do!!welll i guess i will take it apart and see what's inside
304065 04-13-2007 06:44 AM
What number on the case? Should start with 9.
gregk1 04-13-2007 07:04 AM
that number tells the year and what car it came out of correct?? i have allways looked at the back number 901/01 in witch i have two of those motors one mag and one aluminum and come to think of it they both have alloy P&C's
