How to lower compression on a 3.6
What are the options for lowering compression on a 3.6 964 motor? (to get it down to about 9:1 compression)
Shave pistons? Spacers under cylinders? ?? Kirk |
Kirk:
Don't use spacers as that adversely effects deck height. Increasing deck height increases the propensity for detonation by leaving more end-gas at the perimeter of the chamber near TDC. Machine the piston domes but you'll not get it to 9:1 without seriously compromising piston strength,.............. |
I've heard of many people machining the domes of the 964 pistons down to 8.5:1 for forced induction application without any dramas, even for up to 1.2bar of boost.
I believe Henry of Supertec has done this many times with great success, as does Protomotive. The 964 piston crowns are very thick. You can't do it with 993 pistons though. |
Thanx guys.
Im trying to figure out all the options for installing a supercharger I picked up. Its quite the learning curve! Kirk |
| All times are GMT -8. The time now is 11:39 AM. |
