3rd/4th gear shaft disassembly
I was about to re-assemble my transmission now that I've finished cleaning everything up and I've rec'd all my parts. Although the 3rd/4th gear train looks fine, I want to flip the syncros and check the slider. I've been putting this off and considered just putting it back together without disassembling the 3rd/4th gear assy. I wasn't sure how to get the nut off the assy anyway, but I finally found an easy way to get the nut off - I held the nut in my bench vise and found that a 22mm socket fit snugly around the spline shaft at the other end. Turned off easily (see pic below).
Now that I have the nut off, the same technique I used to remove the 1st/2nd gear assy from the shaft does not seem to work with the 3rd/4th gears. With the 1st/2nd gear assy, I protected the shaft end of the gear train with a rag then wacked the shaft end onto my concrete floor - the gears slid off quite easily. This technique is not working with the 3rd/4th gear assy. I'm trying to remove them off the end the nut was removed. Before I try more force, is there a better way? Thanks. Geoff Casings nice and clean: http://forums.pelicanparts.com/uploa...1176564278.jpg 3rd/4th gear assy nut removeal technique using 22mm socket on spline end: http://forums.pelicanparts.com/uploa...1176564324.jpg |
Disregard - I protected the shaft end a little better and gave it a major drop everything loosened up. A couple more drops and everything came off.
Geoff |
That is a brilliant idea for removing and installing that nut. Do you think you have any problem with marring the splines?
-Andy |
I think the splines are pretty hard. I didn't see any marring, and the mating parts slipped on fine. It just happens that the 22mm socket fits on pretty nicely.
Geoff |
Tools made from common socket, extension and old clutch disk and a few bolts, nuts and washers:
http://forums.pelicanparts.com/uploa...1176608674.jpg http://forums.pelicanparts.com/uploa...1176608696.jpg http://forums.pelicanparts.com/uploa...1176608717.jpg http://forums.pelicanparts.com/uploa...1176608740.jpg |
O.K, I play:
Special tool made from a clutch disk and parts of MikeZ's old bed frame :eek: My way is to hold the entire shaft by its large nut in the vice and use the tool to apply torque for loosening/tightening. It's not possible to measure torque but it you use the old mark on the nut flange as reference and go past it a little bit when tightenign so it's in the ballpark. http://forums.pelicanparts.com/uploa...1158706691.jpg |
| All times are GMT -8. The time now is 08:57 PM. |
