need help engine trouble???
I own a 1980 sc that I just had the motor rebuilt top and bottom...It now has three oil leaks just 2 months after the rebuild...my cis system when I got it back was put together all wrong...I had the motor rebuilt by DC AUTO in N.C...a oil tube was also put on wrong which I had fixed by my mechanic delta-v in Richmond...he is telling me I also need a AAV...my car ran strong when I first got it back except for the idle he had to set high to keep the car from cutting off while not in gear...I did not have a problem with my cis before the rebuild, just wanted to take care of a few broken head studs..now my car the other night started to cut off 5 times in a row when I would let it idle...I had loss of power and started to run very rough....I can't afford to make many more costly repairs and I live in Richmond VA...Maybe some one can just give me some insight...this is my first 911 and I love the cars just want mine to run right...thanks
If the engine was rebuilt by a reputable business I assume it has a warranty. It only seems fair that you give them a chance to remedy the problem.
What does that shop (Dc Auto) say about your problems? Are they willing to help? The idle problem sounds to me like a air leak. Did the engine ever back-fire? If so you may have a damaged air box or boot blown off. What does the new shop( Delta V) think the problem is? |
Hop on over to www.dorkiphus.com and go looking for RickV. He can probably help you.
Erik oh, and do whatever Henry says. |
Henry is right, have you contacted the rebuilder? First place to start.
Of course, I just can't remember a time when Henry was wrong. |
| All times are GMT -8. The time now is 08:02 AM. |
