-   -   What Compression can I run with 98 octaine Gas (http://forums.pelicanparts.com/911-engine-rebuilding-forum/342175-what-compression-can-i-run-98-octaine-gas.html)
matty74 04-19-2007 04:47 PM
without haveing to go twin plug?
efhughes3 04-19-2007 04:52 PM
I think the big question here is will you ALWAYS have the 98 available?
matty74 04-19-2007 05:08 PM
Lets assume yes all gas startions in Australia Sell it
efhughes3 04-19-2007 05:09 PM
Sorry, didn't look at your location...
914efi 04-30-2007 09:40 AM
Double check how they report it. In the US they average the two numbers, RON and ROZ. I forget which one is higher, but just make sure you get advice based on an apples to apples comparison.
9elf 04-30-2007 01:42 PM
Matty,
In Australia the quoted octane at the pump is the RON (Research Octane Number).
Our American friends have their fuel quoted with what we call the AKI (Anti Knock Index).
That is (RON + MON)/2
Normal MON (Motor Octane Number) is around the 88 mark.
914efi 04-30-2007 02:24 PM
I guess I got the designations wrong? At least I knew there were a few!
DYB 04-30-2007 08:09 PM
matty,
the row cars have 10.3:1 compression and recommend 98 ron in the owners manual. I would have thought this is as much as you want to go in the compression department.
