carrera RS ignition advance
Hello
I'vejust completed my 2.7RS engine rebuilt, but unfortunately discovered that i don't have the right dizzy...:( the #########001 is on the engine right now. The car seems to ran rather good before. What is your experience with this combo ? would you confirm the advance curves i have, and maybe give me an advice to add some spring to recurve or something like that ? thanks a lot Philippe |
Shouldn't you be looking for a: 0 231 184 004 distributor ? Sorry, I can't help with the advance curve.
Very nice car by the way. |
Hello jon
i mean, i had the ######## 001 dizzy in the car, and put it back again without great success...:) i'm still looking... regards Philippe |
Phillip,
I was going to refer you to a thread from 6-7-01, but after re-reading it, I saw that you had participated in the discussion. It was titled "distributor lube." There was a great deal of information about timing spec's. Hopefully Warren Hall (early_s_man), will comment here, as he is quite knowledgeable about these matters and has an abundance of documentation about it. ps Is the muffler on your car homemade? |
Ignition advance curves.
I don't know if these will help you - better than nothing I guess.
My RS pistoned 2.7 distributor has been recurved to fit this one - mechanical advance only. http://forums.pelicanparts.com/uploa...1177602560.jpg This is the other curve I have. http://forums.pelicanparts.com/uploa...1177602641.jpg Both of these came off other previous posts on Pelican. Good luck |
thanks !
Yes, this are the curves i had... yes the mufler is homemade and sounds really good ! |
| All times are GMT -8. The time now is 05:53 AM. |
