dweymer's Avatar
Suspected case leak-fix ??
So I rebuilt my engine and trans, and have been chasing a pretty good leak. I am beginning to think it is a case leak. Assuming I can find it, is there a way to inject 574 into the leaky area?
I was thinking a hypodermic needle.....
Donnie
Currently Porsche-less.....
Old 05-02-2007, 12:20 AM
Super Moderator
cstreit's Avatar
I doubt it... That case seam is probably only a thou or two at best, I can't imagine what would be small enough to get in there .... Hopefully someone will have a bright idea though!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 05-02-2007, 05:50 AM
Slumlord
Porsche_monkey's Avatar
I don't think there is a short-cut solution.
The best I can recommend is a black mat in your garage. Park with the engine on top of it.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 05-02-2007, 07:41 AM
304065's Avatar
Why do you believe it is a case leak? What seals have you changed?
There is a fluorescent dye you can add to the oil that will glow under UV light, and a UV-emitting penlight and pair of UV-enhancing glasses that will allow you to pinpoint the source. For $19, it's a good step before you decide to split the case.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-02-2007, 08:51 AM
I had a problem with an oil leak comming from the seam just below the front "nose" bearing and I did not want to split the caes. I used a scribe to rough up the area a bit, then used JB Weld. Did not look good, but then you could not see it after the pulley and metal was installed, but it worked.
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 05-02-2007, 10:48 AM
