Chain Boxes to Case Torque?
Anyone know the torque specs for the chain boxes to the case? I can't seem to find any numbers on it in my searches.
Thanks |
These nuts are the same size as the perimeter nuts so I use the same torque. I think it's 18 ft/lbs but I'd look it up to be sure.
-Andy |
Thanks for the respone. My memory was tellng me between 16 and 18 ft. lbs. I went 16 to be on the safe side so will now add 2 more.
Thanks again, Bob |
18# is generally the max you would torque an 8mm fastener to. that would be in the best situation with the fastener attached to steel, so be careful.
| All times are GMT -8. The time now is 06:29 PM. |
