-   -   Afm Starting Point Adjustment (http://forums.pelicanparts.com/911-engine-rebuilding-forum/346196-afm-starting-point-adjustment.html)
kepperly 05-12-2007 12:26 PM
Does anyone know the approximate "TURNS OUT" I should start
at when reinstalling the AFM. I'm talking about the 3mm allen in the left front of the AFM. I am at sea level ( where else would Kansas be) and just want a starting point to get a CO adjustment close before taking to the local Franchise money pit.
Keith Epperly
87 slant nose turbo look carrera cabriolet- 3.Lt.
Steve W 05-13-2007 12:00 AM
try 1.5 turns out, then use the procedure I outlined to adjust the idle mixture with a voltmeter by yourself here:
http://forums.pelicanparts.com/porsche-911-technical-forum/104495-idle-hunting-problem-continues.html
