-   -   Back firing? Is it bad for a motor? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/346810-back-firing-bad-motor.html)
scca_ita 05-15-2007 09:24 PM
I have a 3.8 with ITBs and Electomotive tech3. After hard acceleration up through the gears and then down shift with no throttle (Foot on Brake) my motor back fires a few times. Is this bad for the motor?
Tyson Schmidt 05-16-2007 12:50 PM
Not bad for the motor, but not great for the exhaust system.
It's likely caused by no fuel shut-off on over-run, so you're dumping fuel into the the muffler. There's occasionally enough oxygen to cause a secondary combustion in the muffler or pipes, usually due to a short, unrestricted exhaust system.
304065 05-16-2007 01:21 PM
Don't you have a throttle position switch that will cut off the fuel?
scca_ita 05-16-2007 01:48 PM
Yes, but I am not sure it is cutting all the fuel off. I am going to have the motor put on the dyno soon to dial things in more.
Thanks for the replies.
