-   -   what to do to a '95 3.6l (http://forums.pelicanparts.com/911-engine-rebuilding-forum/347817-what-do-95-3-6l.html)
tradin1 05-21-2007 05:35 PM
i have a 996tt with the UMW 3b kit so i am not looking to spend stupid money for a bunch of unusable power, as my 996 is already there.
with that being said, i do want a fun car to drive. this motor is going into a 72 rsr tribute car that should weigh around ~2500lbs.
as of now it has a BC rebuilt 915 with L/S.
Ollie's is doing the machine work, boat tailing, shuffle pin, cross drill, etc...
what else is there that i can do while the motor is apart that will be the most bang for the dollar. cams, chip, exhaust, diff crank, p&c's...
i was going to use the motronic EFI.
this car will be 90% street car.
Steve@Rennsport 05-21-2007 06:35 PM
Hi:
In this order for maximum bang for the $:
1) Good chip
2) RS cams w/ good springs & Ti retainers
3) Exhaust (there are many options)
5) Mahle 102mm P/C's
tradin1 05-21-2007 06:37 PM
with the mahle 102 p&c's what is the displacement end up, 3.8?
and which chip do you recomend?
is the vram intake worth looking at?
Steve@Rennsport 05-22-2007 12:27 AM
Yessir,....that makes it a 3.8. There are a few P/C options, too.
Call me.
Not unless you make a LOT of changes, no.
