-   -   3.2 conversion from US to Euro speccs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/347900-3-2-conversion-us-euro-speccs.html)
constaf 05-22-2007 05:54 AM
what does it take to convert a 3.2 from us to euro specs? i am looking for the different parts and setups that make the difference between them.
thanks
Rich76_911s 05-22-2007 12:29 PM
I believe the main difference between the US spec and Euro Spec was that the euro spec engine had a higher compression ratio like 10.5:1. So you would need to upgrade to euro spec pistons and cylinders.
Aside from that I think they had a premuffler instead of a catalytic converter. I'm not quite as certain about this though.
Might need a different chip as well.
Rich
Javers 05-24-2007 02:42 AM
Yes DME unit is different aswell, the euro one has no circuitry for the o2 sensor input. That said, I wonder if you could use a euro chip in a us dme and it will just ignore the o2 circuit, would need an expert's opinion on that one. Hmmmmm.
Jon
quint22cp 05-24-2007 10:28 AM
I have 3.2 euro pistons and barrels for sale if you are interested, they have done 67k miles.
lindemans 06-08-2007 03:02 PM
The EU version has different P&C's; these you can swap.
Furthermore EU engines were delivered "with CAT", "without CAT but with all provisions in the DME for a CAT (later 3.2-s)" or "without CAT and without provisions in the DME for one (earlier 3.2-s)".
Having either one of the latter two in EU determines how easy it is (or not...) to install a CAT afterwards.
So, if you have a US 3.2 with a CAT, you can change P&C's and I would assume change the chip for a EU one for the CAT version we have here too.
Steve W 06-08-2007 08:58 PM
You could install a euro chip in a US dme and it would ignore the O2 circuit, effectively functioning like a Euro DME setup. Replace the cat with a euro premuffler, and change the pistons to euro pistons, and you effectively have a Euro spec setup.
