-   -   Help with plug gap (http://forums.pelicanparts.com/911-engine-rebuilding-forum/349531-help-plug-gap.html)
Ducman 05-31-2007 09:45 AM
Help with plug gap
For various reasons I want to try a set of NGK plugs, I am also unsure of the plug gap that the original builder settled on when he used Bosch coppers.
Please help me get a good starting point or at least point me in the direction that will help me learn a good starting point.
Through search of this sight a have a new set of NGK BP8ES plugs.
The engine:
2.7 with RS P&Cs, matched and ported heads
S cams
40 webers
Permatune
The engine is very well sorted - with the only real change of late being new plugs (Bosche platinum) - engine isn't running bad....but it does not seem as "crisp"
Autox and track day car
Thanks in advance guys!
Don
ael911 05-31-2007 12:37 PM
I run my NGK BP7ES at .036 and they run great.
Ducman 05-31-2007 02:15 PM
Thanks! - it's at least one data point
Don
304065 05-31-2007 03:57 PM
I use BP7ES at about 1.3mm and they work great.
Ducman 06-01-2007 04:30 AM
Thanks John
Thats quite a bit larger than the .036 quoted above.
I installed the BP8ES at .036 last night - all I was able to do was start up and idle last night (being kind to my neighbors). I have an autocross this weekend - we'll see how they work.
Anyone have a good source to read up on how to evaluate gap in order to determine if a change +/- should be tested? just curiosity
Don
BURN-BROS 06-02-2007 03:26 PM
Your coil type will dictate the gap. I assume that you run a stock coil so you should keep gap at stock specs. If you were running coil packs then you can run .05 gap. Over-gapping a plug usually results in over heating the coil.
J P Stein 06-02-2007 06:46 PM
At the end of my journey thru the tuning of my 2.7, I found an MSD 6AL, MSD Hi-vibration coil, 8.5 mm Magnacore wires, & NGK BP7ES plugs gapped at .05....humpf, where did that stuff come from?
I have 9.7:1 compression, Solex cams ( great AX cams, I've found), & the infamous Webers. It's been trouble free for 5-6 years...he said while knocking wood.:D
kucharskimb 06-03-2007 05:37 PM
2.2E stroked to 2.4E
Webers
BP6ES @.045
Crane XR3000 Ignition
PS-91 coil
Clewett Wires
9.6:1 Compression
E cams
Over 165 HP at the wheels
