-   -   Threebond 1104 or New 1194 HELP! (http://forums.pelicanparts.com/911-engine-rebuilding-forum/349710-threebond-1104-new-1194-help.html)
STROSEK 06-01-2007 10:25 AM
I'm just about to seal up my case and I just noticed that my sealant supplier sent me threebond 1194 when I had ordered 1104? I went to the threebond web site and they don't even list 1104 anymore and list the 1194 as being "New". Does anyone have any experience with this I'm a little reluctant in using potentially the wrong sealant on my case.
Any information would be appreciated. I have a feeling that the 1194 is a replacement part# but I want to be sure.
Thanks!!
STROSEK 06-01-2007 10:45 AM
Well I'm going to reply to my own post with the answer I'm looking for and hope that the info will one day help someone else answer the same question...
So here's the scoop!
I called threebond and according to them the 1104 has been discontinued because it has lead in it. It has been replaced with 1194 which the same product just a lot safer. So 1194 is a direct replacement to 1104.
Hope this info helps as i'm sure others are going to be running into the same situation in the near future as the old stock of 1104 runs out.
Cheers!!
Jeff 04-18-2008 09:02 AM
Thanks Strosek. I just ran into the same issue after trying to track down 1104.
How did the 1194 work for you?
STROSEK 04-18-2008 10:13 AM
It worked great! Just remember to have everything ready to go and have ALL your ducks in a row before you start laying it down because it sets up fast.
Glad my post was able to help at least one person lol..
All the best!!
sabeo.m 04-18-2008 12:20 PM
I was just about to ask the same question about 1104, you beat me to the punch, thanks! :D
Nitrometano 04-19-2008 06:03 PM
you are using theebond to seal the crankcase halves and between the cylinder heads and camshafts housings?
Jeff Alton 04-19-2008 07:00 PM
That is what I do.
Cheers
Nitrometano 04-19-2008 07:38 PM
it works better than the Loctite 574 against oil leaks? I use on my jetski engine Honda Bond.
Jeff Alton 04-19-2008 10:47 PM
There is plenty of debate here about which sealer is the best. There are a few good threads on this forum to search out.
Cheers
Porschekid962 04-19-2008 11:22 PM
Head to your local Honda or Yamaha dealer and pick up some Hondabond or Yamabond. Stuff works great. Put it on your case halve, let it tack up a bit and slap it together. The really are nearly identical so either works a trick.
SCrescue 04-21-2008 06:45 AM
I'm getting ready to reassemble my engine also, and it appears that the general consensus lately among many with experience is that threebond is the superior product to loctite 574 for case sealing. Is that a fair statement?
Mike
preston_brown 04-23-2008 08:42 PM
I used 1194 on my case halves as well, and not even the hint of a leak. Nice stuff. I can't compare to Loctite.
1982911SCTarga 04-24-2008 05:51 AM
I'll be using 1194 on my heads-to-cam towers interface.
Brian
YamaBlonde 07-04-2010 10:52 AM
hi, I know a place in England that sells ThreeBond 1104 and ships internationally. If you want the guy's contact details, I wll gladly supply them.
He says his price to ship one tube to the US (all inclusive) is about $17USD.
Am I allowed to give someone else's web address or email here, to share his info?
Kind regards,
Debb (in the UK)
YamaBlonde 07-04-2010 11:03 AM
p.s. He has an eBay shop too: rexcauntracing -- but I think that may be more expensive than going to them directly, because of ebay and Paypal fees.
smoothSC 08-09-2010 07:23 PM
Another thing that is great about ThreeBond 1194 etc. is that it is easy to remove for the next rebuild. Wipes right off with Acetone.
pirin911 10-02-2010 07:28 AM
Hi:
Do you apply a thin coat of ThreeBond 1194 to one case halve or to both halves?
Henry Schmidt 10-02-2010 05:41 PM
The difference between 1104 and 1194 is led.
Products with led are illegal in the US.
nocarrier 10-02-2010 06:30 PM
Henry, I remember you mentioning that the 574 is used on the bearing webs for its shear strength.
If I was going to use the 574 on the webs near the bearings and the three bond elsewhere. Would you think that shuffle pinning the case would be a good idea to supplement the shear strength of the 574 only being on the bearing webs?
Sorry if I hijacked!
Henry Schmidt 10-02-2010 06:33 PM
If you shuffle pin the case you will render any shear benefit offered by the Loctite inconsequential.
nocarrier 10-02-2010 06:53 PM
Thanks Henry, It's really cool you let us pick your brain on here !!
-Adam
MBruns 10-06-2010 02:49 PM
1211
Henry do you stock the 1211 ?
Mike
Henry Schmidt 10-06-2010 03:58 PM
Mike
Yes
We also sell a complete sealant kit for DIY engine builders.
http://forums.pelicanparts.com/uploa...1286405917.jpg
theiceman 03-31-2016 02:02 PM
Cheers!!
I realize I am bringing this thread back from the dead but I am only doing it to help future people. according to this post 1104 was discontinued. this post was made in 2007 . That means that any 3bond 1104 you get will be 9 years old.although my tube was bad i have to believe it was re introduced.
Hope this helps.
