Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Stripped Cam Conical Nut
I knew this was going to happen. I had a tough time with several of the 8mm conical nuts in the cam housing - that hold the rockers to the cam housing.
The LAST one I went to remove did strip - in the head of the nut. Those things are sooooo shallow.
Any tips as to removing??? This seems like a real bugger. The rocker is #5 - all other rockers have been removed.
-Rob
'79 SC
Old 06-02-2007, 05:20 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Home of the Whopper
BK911's Avatar
I usually hold the 8mm and turn the other side, it's a 5 or 6mm. Remove the oil cooler if necessary.
'62 356B S90 Coupe
'72 914 1.7
'73.5 911T 3.0 Coupe
'67 Aermacchi/HD Sprint 250SS
Old 06-02-2007, 05:52 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Oil cooler gone, I thought Wayne's book said not to turn the 5 mm side, it could damage the shaft?
'79 SC
Old 06-02-2007, 07:19 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Home of the Whopper
BK911's Avatar
You may have it backwards. Either way, you don't have much choice now.
'62 356B S90 Coupe
'72 914 1.7
Old 06-02-2007, 07:25 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Yea, maybe I do have it backwards! Anyways, I turned the 5 mm and presto, it came out. Thanks!
'79 SC
Old 06-02-2007, 07:33 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Jeff Alton's Avatar
Yep, never turn the nut, only the bolt.
Glad you got it out!!
What are your plans now for this motor??
Cheers
jeff@turn3autosport.com
Old 06-02-2007, 08:18 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
DC40 cams (you wouldn't happen to have a set? as you sold me your DC20s), Mahle Motorsport Pistons 10.5:1 and 46mm PMOs
'79 SC
Old 06-03-2007, 03:57 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Jeff Alton's Avatar
Sounds like a cool motor! I don't have any cams here right now, but John can set you up!
Cheers
Old 06-03-2007, 12:14 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
