-   -   2.7 Carrera pistons 2nd Thread. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/349987-2-7-carrera-pistons-2nd-thread.html)
HKZ Bob 06-02-2007 10:42 PM
Dear Team, what are the correct tolerances & values for this pistons. Who knows whats wrong here.
See as well the aftermarket piston.
http://forums.pelicanparts.com/uploa...1180852925.jpg
http://forums.pelicanparts.com/uploa...1180852966.jpg
HKZ Bob 06-02-2007 10:46 PM
http://forums.pelicanparts.com/uploa...1180853075.jpg
http://forums.pelicanparts.com/uploa...1180853107.jpg
Why is the Aftermarket piston 89.98
There should not be that value.
Eagledriver 06-03-2007 04:07 PM
What is it you are trying to determine? You have the measurement of the pistons. They seem to show up (at least very close) on your charts and a "2" for the Carrera RS chart. They also are the same size as the "1" on the 74-77 chart but so what. They are clearly 73 RS pistons. If you look at CIS pistons you'll see the difference.
-Andy
HKZ Bob 06-03-2007 09:55 PM
There should not be a 73 Carrara 2.7 piston with 89.98 according porsche charts.
Eagledriver 06-05-2007 01:46 PM
You're right the number is 89.975 for the maximum on the "2" size. That is what I mean't by "at least very close" in my post. You are looking at a .005mm difference.
Are you trying to use these? Are you trying to replace them? Are you trying to buy new cylinders? What are you trying to accomplish?
-Andy
