-   -   What is 993 RSR head stud torque? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/350374-what-993-rsr-head-stud-torque.html)
JoeMag 06-05-2007 06:37 AM
not sure if they're different than stock 993 (but don't know that value either).
racing97 06-05-2007 11:48 AM
If the stud is of the all-thread varaity it would be 30nm + 90 degrees. For some reason the same stud in the GT2 racing engine was 30 + 120 which was and is amazing to me.
regards
JoeMag 06-05-2007 02:05 PM
they're definately not threaded all the way down...
http://forums.pelicanparts.com/uploa...1181077525.jpg
racing97 06-05-2007 02:49 PM
That is fine, the originals are all thread but that is not necessary at all.
In your case 25 fps should do it with a lilttle lube, oil or such. With the bigger bores I favor putting the heads on the barrels and the cam tower on "dry" with a few bolts to fasten and index the dowel pins between the heads and tower, then torque each barrel individually to secure the big jug squarely.
regards
