-   -   what do you think of this engine? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/350856-what-do-you-think-engine.html)
rfuerst911sc 06-07-2007 06:00 PM
In my search for an engine for my project car I have found the following: a 1971 911T engine that has had all the machining done ( flat ground case,line bore, etc. ) by CE and it has a 2.7 crank,rods with 84mm Biral cylinders with S pistons and E cams. I believe this makes a 2.4 litre? Anyway it appears to be a well done long block that needs assy. I'm guessing this is a 170-180 horse engine? Also has had oil bypass done and has a 3.0 oil pump. What are your thoughts on this setup for a AX/weekend car?SmileWavy
Eagledriver 06-07-2007 08:00 PM
Sounds great. I think you are right on with the power estimate and much better torque curve than a 2.4S engine.
-Andy
