HKZ Bob's Avatar
Loctitde 574 on No.1 bearing
Hello Folks
to improve the oil pressure I thought to put some 574 on the No.1 bearing. This avoids that oil pressure will be reduced due to slight leakage between case & main bearing.
What does the expert say.
bob
Old 06-08-2007, 09:33 AM
don't try it.
206 637 4071
Old 06-08-2007, 11:07 AM
You are putting an anerobic sealant into the oil system on your engine. Not a very good idea.
-Andy
Old 06-08-2007, 11:48 AM
HKZ Bob's Avatar
But there is a weak point of the system. We are doing everything
to improve oil pressure.
But what about here ?
I thought Loctite 574 does not plug up oil channels. Am I mixing things here. Is there an sealer which in uncritical for the oil channels.
Regards bob
Old 06-08-2007, 02:06 PM
If it is meant as a fix for low oil pressure: fix the real cause.
Otherwise leave as is, wel built engine with proper tolerances has good pressure anyway.
Only suggestion I have to increase pressure to main barings: install oil line restrictors in feeds towards to top-end. if you don't have threm on your engine (later on it became a factory mod.)
Better a good one for a lot of bucks, than a bad one for little
Old 06-08-2007, 02:44 PM
that crap sets up sooner than you think when deprived of O2. there would be a thick crust between case and bearing that would not squeeze out because it hardened before you got everything torqued up. so don't try it.
206 637 4071
Old 06-08-2007, 03:31 PM
Bob,
I applaud your efforts to do every little thing you can to improve your engine, however in this case the risks far outweigh the rewards. Your efforts will be most effective in attention to details like keeping all the parts very clean, measuring everything several times, and going over the plans/procedures in your mind several times before doing the action.
-Andy
Old 06-08-2007, 07:02 PM
I don't think that oil pressure is a weak point in these engines. Even with the early pump and before the bypass mod the bottom end on these engines lasted for over 100,000 miles. The only time I've ever seen serious wear on the bearings is in cases of oil starvation.
-Andy
Old 06-08-2007, 07:05 PM
