-   -   Anyone use a roller to apply Loctite 574 to Case? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/352100-anyone-use-roller-apply-loctite-574-case.html)
sms1305 06-14-2007 02:11 PM
So far, I've heard of four methods for applying the case sealant.
1. small bead
2. finger
3. acid brush
4. roller
Roller seems best to me, but I haven't found any info about exactly what kind to use. Wayne says acid brush in his book. Anyone use a roller and have a good experience?
Thanks!
Eagledriver 06-14-2007 06:15 PM
I bought a small roller from Ace Hardware. It's about 4 inches accross and 1.5 inches in diameter. It helped to spread it evenly. You need to use the sealant sparingly so it doesn't get into the oil passages.
-Andy
BoxxerSix 06-14-2007 07:40 PM
A rubber roller is the best, the type used for ink transfers....small 1" wide sponge rollers are the next best alternative and are readily available at any Lowes/H.Depot in the paint/stain section...
