ARP Head/Cylinder stud torque?
I'm in the middle of my 964 rebuild and need some advise... What is the correct torque spec for ARP head/cylinder stud bolts?
The back of the ARP box has one thing, Waynes rebuild book has another and my 993 factory manual has something totally different. They all can't be right!! If someone could give me the exact torque specs for this application it would be appreciated. Thanks in advance. |
You need to make sure that you have the right instructions for the kit that you have. Looking at the ARP catalogue, there are two kits for 911s. I have #204-4206 (911 and 930 turbo). The other kit that I see is #204-4210 (996).
Here's the instructions on my sheet for the 4206: QUOTE: (3) If cylinder head studs protrude into blind hold, lubricate the threads, nuts & wahsers with ARP MOLY ASSEMBLY LUBRICANT. NOTE: Loctite may be used if a permanent mounting of the studs is prefered. The fasteners, however, must be torqued prior to the loctite setting up. (4) Install cylinder heads and check for binding or misalignment. (5) ARP recommends using the ARP MOLY LUBRICANT or at hte very least, a good quality Moly Lubricant as opposed to motor oil. This is due to higher friction on the studs as well as inconsistencies in the clamping force of the fasteners when motor oil (or low quality lubricant) is used. PRELOAD (TORQUE) RECOMMENDATIONS: Torque values are based on 75% of the fasteners yield strength. Use the manufacturers torque sequence but do not use the engine manufacturers torque specs. Torque the nuts to 38ft. lbs with ARP MOLY ASSEMBLY LUBRICANT Note: Do not use any other Moly Lube. Use only ARP MOLY LUBE or head gasket failure can result. END QUOTE I'm still trying to determine whether the height is 135 mm or 132 mm as the book states. I don't know if the same instructions apply if you're using the 4210 kit. Good luck!! |
I just spoke to an ARP tech rep. He said that you must reach final torque within the time specified, which means you need to install the piston, cylinder and head within 30 minutes of installing the studs.
No one has ever mentioned this that I've seen, but it seems like it will be a real race to get everything done in time before the loctite sets. Does this make sense? |
No it doesn't make sense. I suspect the 30 min thing is for using locktite. I don't have experience with these studs but I would be worried that 38 ft/lbs is too much for the case and heads to take. The heads could be distorted or the studs could pull from the case. I don't know the right answer these are just my thoughts. Hopefully someone more qualified like Steve or Henry will help.
-Andy |
So, how do you torque the nuts when you rebuild a motor with ARP studs, pull them all out and do the rat race againg installing everything?
Cheers |
I used 32 Lbs and am done with it. It's a little more then Waynes book calls for and a little less then ARP calls for on the box. I'm sure it will be just fine. Fingers crossed!
Thanks to everyone who replied. |
Hey, good luck.
I was wondering what, if any, loctite you used on the bottom threads? Did you assemble all the studs before installing the cylinders and heads or did you go one at a time? |
The torque on a fastener is a function of the fastener being used - don't go by what Wayne's book or the factory manual says for a "similar" fastener. This time you will probably be OK but in the future do not use the reasoning that you used to come up with your compromise torque - follow the fastener manufacturer's instructions.
The manufacturer is trying to produce a specific tension/bolt stretch in their fastener. Simple torque or torque angle is a crude way of obtaining that tension. BTW: Raceware head studs are also put in without Loctite. -Chris |
I did use locktite red on the studs, the case side not the head bolts... Do you think I should re-torque them to 36 lbs? I don't think it's too late? I had read that someone had pulled the studs out using too much torque and another post saying that 32 to 34 was about right with the ARP and that the ARP recommended amount was a bit high.
Re-torque from 32 to 36 or leave it? Thanks!! |
I would retorgue to the number that ARP supplied. Like Chris said, the torque spec is about stretch or tension on the stud. I would use their figures.
That is what I did when I installed the ARP studs on my motor.... Cheers |
Do you guys have any thoughts about using loctite on the ARP head studs with timecerts? The instructions indicate that they can go in with or without, but that if you do use loctite that you need to get to final torque within 30 minutes. When I talked ARP the tech guy said that that meant I would need to assemble the cylinders and heads and get final torque on the nut since there's no torque for just the stud.
p.s. I'm the guy with the two pulled studs from the last top end build. I did use loctite, but definitely did not torque the heads within 30 minutes. Thanks. |
Surely the short answer to this question is not to use any thread locking compound on the case end of the studs. You don't need it to get the clamping force required to keep your heads in place. And you don't need it to keep the head studs from somehow backing out of the case on their own while driving around. Just won't happen.
Now a thread locker may prevent the stud from backing out when you go to remove the head at some time in the future. But I haven't had this problem, and even if it happens it doesn't have to be a big deal - it will only happen in the context of a top end teardown and you will be able to get the stud out, remove the corroded nut, and reinstall the stud. This is the first I've heard of a recommendation to torque a threadlocked stud within X time of application. This must be based first on the setting time of the thread locker. But it also has to be premised on the notion that the thread locker which has set up without the stud being under tension will hold the stud deeper into the case than would otherwise be the case. And that when you torque you stretch the stud based on that depth. But as the engine undergoes heat cycles the thread locker will fail/loosen/relent/compress, and the stud will be pulled upward, which will cause it to lose some of its stretch/tension. At least that is the only thing that occurs to me which could account for caring about this thread locking issue. The Porsche shop manual doesn't say anything about this. And were it not coming from a source like ARP, I'd dismiss it, as the amount of difference has to be pretty darned small if I have guessed correctly what the concern is. Now if they are working off of experience with Detroit V8s, and replacing head bolts with studs, it would seem fairly easy to do a stud for bolt swap in 30 minutes, especially since you could do those one at a time if you wanted. And those studs would be a lot shorter than ours, so a small length difference would mean more. Walt Fricke |
I already purchase an ARP head studs for my 2.7 engine. I also notice today the 38 ft/lbs for torque. My engine is the magnesium case and has Timecerts inserts installed. I have the same doubt about that much torque for the headtuds. The bigges preocupation that I have is that torque will pull out the inserts. After reading this forum, I think that the correct installation for this studs are without loctite in the engine case side. I also notice that the instruccions underside the box dont tell anything about using that. An there is no stretch method for this studs like the ARP rod bolts. Please let me know if I'm correct:
Install the head studs to the case side without thread locking compound. Use the ARP moly lube on the cylinder head nuts. Torque the head studs to 38 ft/lbs with case inserts installed into a magnesium case? After your people, what have been your experience with this studs? Do you get a cylinder head leaking after the installation and running a few miles whit the engine? Do you retorque the head studs? They pull out from the engine case? |
the bentley manual says "pre torque 15 nm (11ft-lbs) then 90 degrees(1/4 turn). I am sure this is more than 38ft lbs.
studs
The stock studs for the 964/993 with the 11 ft # plus 90 deg ends up around 40 - 42 ft #, I would not put that much on a mag case.
Mike Bruns |
Bruce Anderson, in his 911 book, says torque head studs to 25 (steel) or 29 (Dilivar) pounds/foot. That's what I have done with mag cases and with early aluminum (sandcast) cases.
Henry Schmidt specifies the following torque for his Supertec studs: Sandcast aluminum: 30 Mag: 26 Pressure cast aluminum NA motors: 30 Aluminum turbo motors: 32-36. Looks like 26 would work. 38 seems way too high for a mag case, time certs or not. |
FWIW, just finished installing the cam boxes and torquing head studs on a 964 C2 with Canyon steel studs. 15 ft-lb + 90 deg = 28-29 ft-lbs (11 ft-lb + 90 deg ended up being anywhere between 24-30 ft-lbs for me at least).
The workshop manual also specifies that the bearing surface of the head nut (washer if separate from the nut) be lightly lubed with the same anti seize as the stud threads. |
I just a few weeks ago I torqued my ARP’s to 38ft/lbs. First 19 and then 38. Lube on threads and washer.
Since my reply back 2007 I have lost count of how many sets of ARP studs we have installed. 25? Always torqued to the ARP recommended torque. Just completed a 993RS motor built out to 4.1 where we used ARP studs. Not worried about it in the least.
I struggle to see why people think they should use other than the recommended torque value supplied by ARP, when all they do is engineer fasteners.... We have had ZERO issues following ARP directives in the 17 years since this thread started. Cheers |
And then there is this. I have just been down the same hole, and came across this thread.
https://forums.pelicanparts.com/porsche-911-technical-forum/1115709-arp-head-stud-torque.html How do you make sense of all this? Alan |
My own take, as an engineer: The torque spec Porsche gave for its steel studs is enough to keep the heads clamped tightly on the cylinders. More than that is nice, but not necessary. The ARP studs can go higher yet, but presumably ARP has done their engineering and testing to justify even more torque. Thus, a value above the Porsche spec, but not more than the ARP spec, "should" work.
The downside, as mentioned in that other thread, is that higher torque will cause more distortion of the heads and cylinders, and case. possibly causing pulled case threads. Judging from the structure of those parts, I don't think that is a big problem; and I have not heard of anyone running ARP studs to have had problems using their spec torque. So it's probably not an issue either way. I like the compromise that ARP offered of 28 lb-ft. But, what I would really like to see is ARP make their studs thinner, so that they are "stretchier" to accommodate the growth of the engine without increasing clamping force as much due to that growth, and then reduce their spec to 28. |
That makes a whole lot of sense.
I finally settled on 28 after going thru these threads. The problem, for me is I have 2 other heads which I can't remember what I torqued to. Since I had just removed one head. But there is no cam binding and I may well have decided on 28 previously. Whatever the value I used before they are performing just fine so was reluctant to break the torque on them. If I don't have cam binding even if some are at 28 and some at 38 I suspect I will still be OK. Each head doesn't know what the other has. Just the cam box. Alan |
Use what the manufacturer of the bolt/stud states, unless you can prove a different method would yield better results... Cheers |
1. The material in both the Porsche and ARP studs is high carbon alloy steel. Nearly all carbon steel alloys have the same Modulus of Elasticity (about 29Msi/200GPa).
2. The Porsche and ARP studs use the same thread size and pitch (helix angle), as do the Supertec studs. Therefore, X ft-lbs of torque on any of them creates the same clamping force (assuming they are both lubricated and tightened the same way). The 3.0 and later aluminum cases can take much more force than the magnesium cases, therefore, I would be less concerned about increasing the torque on the studs in those cases. However, I would not exceed the Porsche spec by much in a magnesium case, even if it has had case savers installed. You have built more of these engines than I have so you have more practical experience than I do. if the engines you put together don't pull studs or have other problems related to higher stud torque and component distortion, then keep doing what works for you. I don't know what the Supertec studs torque spec is. Does anyone else? |
Do all available studs have rolled or cut threads?
Rolled.
" I don't know what the Supertec studs torque spec is. Does anyone else?"
Found in archives Alan tourque spec (+ and - 2lb standard tourque pattern is maintained a. 2.0 ally case = 30lbs b. 2.0,2.2,2.4,2.7 (all mag cases)= 28lbs c. 3.0, 3.2,3.6 ally case =30lbs d. 3.0, 3.3,3.6 ally case turbo= 35lbs |
Had not considered the Mg case motors as we always use OE steel studs on those. However, It would be intersting to see what the different materials are (despite all being High Carbon Alloy Steel) between Factory, ARP. Canyon, Raceware, Supertech etc that makes their in house engineers come up with a different torque spec. Interested from a learning perspective. I would acutally like to know. Maybe Henry will chime in, as someone who went down the path of contracting the engineering of a head stud. Cheers |
It's not only the alloy, but the forming of the stud and heat treating that affect the strength. The ARP stud is an austenitic alloy, so to develop maximum strength, the heat treatment is very important. From ARP's web site:
"ARP only uses premium grade 8740 alloy and a proprietary ARP2000® alloy that are rated far superior to “aircraft”quality alloy steels. Secondly, each stud is placed vertically into special racks and precisely heat-treated to 190,000 psi for the 8740 material and 220,000 psi for the ARP2000® material." https://arpstore.com/products/cylinder-head-stud-kit-for-porsche-2-0l-3-8l-air-cooled-engines-911-930-turbo-premium-austenit The other vendors almost certainly use the same 8740 or extremely similar steel alloys Pushing this discussion a little further: If I were engineering the studs, I would use the same alloys but I would make the studs thinner. If the ARP studs are good for a torque of 38 ft-lbs, and 24 ft-lbs is sufficient to hold the head on the cylinders, then the ARP studs are 58% stronger than they need to be. Therefore, I would design them to be 36% thinner in cross section than the ARP studs. This would make the studs "stretchier" by the same 36%. When the engine grows due to reaching operating temperature, those studs are stretched by the growth of the heads and cylinders. That increases the stress in the studs, which increases the pulling force on the threads in the case (and the head nuts, but those never pull out because they are steel too). If the studs were thinner, they would not create as much force on the case threads as they stretch. Therefore, the cases should resist thread pulling and case distortion better. Thus, "weaker" studs would build a "stronger" engine. |
What I am curious about is the fact that Porsche say 23 ftlb is enough for my 930 heads.
So why would other stud suppliers decide they need up to 38 ftlb to tie down the same heads - esp if they are using basically similar materials. Alan |
I guess if the factory torque specs "are sufficient" and the studs are fine. Why the aftermarket head studs????
There are some assumptions being made the the factory torque on thier studs is sufficient, and that it should apply to all studs.... Again, approaching this from a learning perspective..... Like I said earlier regarding rod bolts.... Sure same basic material, but why higher torque? Even Porsche dramatically changed the torque spec on those bolts with a slight change in material that likely fell into the "same class" of material... Lets keep the discussion going so we can all get more info. Cheers |
Jeff, fair question. Many people who build race engines believe they have to use the "best" of everything. That ain't necessarily so.
Why? You would have to ask ARP. Like a lot of things sold under the "performance" labels, marketing is a significant part of the game, because in a lot of customers' minds, "more is better." Racers are notoriously susceptible to this line of thinking. They see someone else winning races and see that they use certain parts (suspension, engine, aero, tires, wheels, anything else) and they want the same things. The companies that make these parts are all to happy to oblige. In reality, they just aren't as good drivers as the fast guys with names like Hamilton and Verstappen. :cool: When Porsche came up with the 24 ft-lbs torque spec for the SC engines (including turbos!), and subsequent X ft-lbs + additional angle spec, they added some factor of safety to allow for unusual cylinder pressures due to detonation, some deformation of the case, cylinders and heads, etc. Thus, that torque spec has a safety factor built in. The actual stud torque needed to develop sufficient clamping force to keep the head sealed to the cylinders is less, I'll take a SWAG around 18ft-lbs or even less. The ARP spec is more than twice that. Higher clamping force (and thus higher torque on the studs) may be required if you can push the peak cylinder pressure higher than the Porsche design, for example if you increase the boost, or use nitrous shots, or alternate fuels. If you build nitromethane-eating engines for drag racing, do whatever you have to do to hold the engine together for that last pass! For the aforementioned reasons, I would stick to Porsche's specs or only increase them moderately. When I built my engine, I used the Porsche steel studs to replace the lower row of Dilavar studs on my SC engine case, and I stayed with the original torque specs. I didn't see any need to spend hundred$$ more on ARP studs. Late Edit: And here's another reason not to increase the torque on the studs: The more stress the studs bear, the more susceptible they become to "stress corrosion cracking." This occurs when corrosion attacks the surface of the stud, and with stress on the fastener, the corrosion pitting causes stress concentration, which accelerates the development of cracks. BTW, high strength alloys also generally are more susceptible to this problem. The torsion bars in the suspension are coated in that thick red paint AND coated in thick grease for the same reason, and why the manuals tell you to inspect for any scratches in that paint and to touch it up. I also spray my studs with black epoxy paint before I install them. Belt and suspenders... |
Yes, my uneducated guess goes like this. Porsche can do it with 23 ftlb. But we are selling aftermarket 'performance' products. Therefore the customers do not expect or accept failure. So if I was running that promo, I would be adding an extra safety factor - within the limits I had figured nothing was going to bust.
Not dissing any of them - lucky to have these guys in the market and I have ARP in the engine. Just trying to figure why they came to different conclusions for the same solution. Alan |
Different trade-offs. I don't know what those are for ARP or others, but there are almost always many ways to design a part. Cost is a big driver for OE manufacturers. Not as much a constraint for the "performance" aftermarket.
Pete,
Had not considered the Mg case motors as we use factory steel studs in those top and bottom. All with case savers, as if you rebuild one without them, well.... So good point I had not thought of. Cheers |
I was curious so I looked at the torque specs of other M10 studs used in other locations on 911 that are aluminum. I figured If they are all aluminum with steel studs then that amount of torque should be acceptable for head studs to not pull out threads on initial torque as well. I only looked at Aluminum cases and transmission torque specs.
3.0 head studs are 26ft/lbs Front engine mount cradle is 29.5 ft/lbs A couple of transmission studs are 34 ft/lbs I found some references to GM LS aluminum engines with m10 studs having torque specs of 37Ft/LBS Now some of these are going to be subjected to less additional tension from engine expansion than head studs but gives some comparable information. So 38ft.lbs is probably not going to pull out the aluminum threads unless already damaged. Not sure what it will do to head and cylinder deformation. john |
