Help With Piston ID
The 95P30 are Mahle 3.0 RSR 10.2 CR pistons.
Check my reply here: http://forums.pelicanparts.com/showthread.php?s=&threadid=337695 |
Thanks Tom.
Now the rest of the questions. I run these pistons with a single plug ignition and presently mix 50/50 110 & 93 octane. Is this fuel mix adequate for this set-up? Would I benefit going to straight 110? Would I benefit going to a twin plug set-up? Thanks, John |
Most experts agree that 9.8 CR is the limit for pump gas. As long as this motor is always using race gas, you are probably OK with single plug.
I would get some expert opinions before making a final decision. |
| All times are GMT -8. The time now is 06:45 PM. |
