965 Cam timing value
Looking desperately for the 1992 stock 965 (3.3L turbo) row cam timing tdc overlap in mm and/or inches?
Thanks for your help |
HI GAJ the info is;
engine;M30/69. L/H cam 930 105 143 03. R/H cam 930 105 246 00. cam ID; L/H 930 143 03 R/H 930 246 00 Cam timing at TDC overlap with 0.1mm valve clearance. 0.60-0.65mm. regards mike |
Thank you very much!
| All times are GMT -8. The time now is 06:59 PM. |
