-   -   HELP! How to remove 964 Engine from tranny (http://forums.pelicanparts.com/911-engine-rebuilding-forum/354720-help-how-remove-964-engine-tranny.html)
Ho Hum 74 06-29-2007 03:39 PM
Is there a trick to this? How do I get the clutch fork to release?
john walker's workshop 06-29-2007 04:32 PM
you attach a slide hammer with a 8mm stud in it to the cross-shaft and GENTLY tap it out. spray penetrant in there if it resists much. if you get too rough, there's a chance the shaft support ears can break off, and then you have lots more work.
Ho Hum 74 06-29-2007 04:37 PM
Are you talking about tapping the pin of the clutch fork out? From the open side? Why do you need the 8mm stud? I see that it's threaded in there.
john walker's workshop 06-29-2007 04:47 PM
that's right. the stud is on the slide hammer and you thread it into the shaft.
Ho Hum 74 06-29-2007 07:29 PM
john walker's workshop 06-29-2007 07:39 PM
to add to my last post, once the slide hammer with a homemade, 8mm stud or bolt is threaded into the shaft/pin, then you pull it out of the open side, by gently knocking the slide hammer in the direction required to pull the shaft/pin out. be gentle and have patience because they can be quite stuck at times. you do not want to break off the ears that the shaft goes through.
sww914 06-29-2007 09:55 PM
Just to help clarify- you PULL it out, using the 8mm bolt so that you have something to grab. That's why they threaded it, so that you'd have a way to pull on it.
Ho Hum 74 07-02-2007 05:48 AM
I got it. Thanks!
