vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Rod Bolt Source
I am looking for a source for rod bolts? Anybody? Everybody says to change these when you rebuild but I can't seem to find someplace to purchase?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 07-21-2007, 05:09 PM
Vance:
Have you considered buying them from Pelican???
I know they carry both factory and ARP ones,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-21-2007, 05:36 PM
Jeff Alton's Avatar
If these are for the SC listed in your sig, then just you should be fine with a set of factory nuts and bolts (assuming a stock rebuild) The factory bolts are a "one use only" bolt. They can be torqued but once.
I would take Steve's advice and order a set from Pelican.
Cheers
www.turn3autosport.com
Old 07-21-2007, 10:57 PM
vesnyder's Avatar
Sorry for not being clear but these are for my 914. I've found the nuts on the Pelican site but no bolts?
I posted here because I've had little to no response on the 914 site. Pelican is my first choice!
Vance
Old 07-22-2007, 06:08 AM
MBEngineering's Avatar
HI which engine in the 914 =4 or 6 cylinder?? for the big end bolts/nuts.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 07-22-2007, 07:40 AM
vesnyder's Avatar
This is for the '75 1.8l four cylinder. There has to be a cheaper option than the ARP bolts?
Vance
Old 07-22-2007, 02:13 PM
Hello there.
Its not normal rebuild practice to change rod bolts on the four cylinders: only the nuts.
If you really want to get stronger bolts I'd see what the VW sites have to say..
Kind regards
Old 07-23-2007, 12:20 AM
vesnyder's Avatar
I assumed after finding that nobody sells them, but several people have told me otherwise? I found a cheap source and will most likely change them unless the machine shop charges are outrageous. Why would people recommend changing the rod bolts on a 911 and not the Type 4?
Vance
Old 07-23-2007, 04:34 AM
hello, vance.
Its not merely arecommendation.
Its the factory spec: the design of the bolts is completely differnt.
the 911 bolts are permanently strecthed when installed correctly.
But the 914 bolt is designed to operate within its elastic limit.
Kind regards
david
Old 07-23-2007, 04:44 AM
