I had a bad day . . .
Turns out that one of my head studs were bent, so after installing all the cylinders I decided I needed to remove it.
While taking it out, the stud came out with the timesert. As if that wasn't bad enough, it damaged the bottom of the cylinder. I don't know what to do.
Steve '89 Carrera 4 |
install another timesert and carefully file the cylinder base flat. new studs are not usually bent. did you do all the drilling and threading for the inserts in a mill, or by hand?
John: Always great to see you posting on one of my problems...
I had the inserts done by a machine shop in Reno, by Augie, through EBS. I didn't notice the stud was bent when I took it out, but noticed when I put it in. Stupidly, I left it in before I decided to replace it. By then the loctite had set. When I was taking it out, the cylinder was already mounted. I didn't realize it was pushing against the bottom of the cylinder until it had already gouged it. Local machinist inspected and filed the bottom for me - for the cost of a 6 pac. I got a replacement timesert from a local Porsche mechanic (Derrick at Eurosport in Virginia Beach) along with his installation tool. Howerver the insert measures .8 inches and it seems a little shorter than what was put in by the machine shop. The insert I have doesn't cover all the stud threads. Is there a longer version that would be better? Thanks!
there is a longer one. don't use the shortie. timeserts are kind of soft for this application.
