-   -   2.7 rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/355546-2-7-rebuild.html)
SigmundF 07-04-2007 01:51 PM
2.7 rebuild
Hi
I am planning to rebuild my 2.7 CIS. When I have the engine apart I was thinking I could try to get some more HP out of it. I was thinking of keeping the CIS, change the cams to 964 profile, change pistons to increase the CR to approx. 9.5:1 and backdate the exhaust (SSI).
Anyone have any experience with a setup like this or have any comments/suggestions? What can I expect of horsepower for such a setup?
psarmany 07-04-2007 09:35 PM
Sigmund, I'll be watching this thread closely as this is an upgrade I'd like to do in the future. I believe there's some good info on this topic in the 911 technical article section. Good luck, Pete
SigmundF 07-05-2007 12:11 AM
Yes, I plan to use the CIS. As far as I know it should be possible to get some 90mm JE pistons that will increase the CR to 9,5...?
RoninLB 07-05-2007 07:20 PM
i used forged 8.5 RS pistons w/CIS and no problems.
afterburn 549 07-11-2007 10:28 AM
what was the hp. formula 10 per pt of c/r bump??
From the archives of what I think I know..the CIS will not care what your pistons look like or their c/r The cis will not work with cams that have over lap ( flapper valve jumps with the reversion thing)
Jim Housman 07-15-2007 09:06 PM
I did a 2.7 about 8 years ago with SC cams, Euro pistons and kept the CIS. I milled .030 off the heads to get 9.0:1 CR. If anyone is interested I have dyno results of the engine in Excel format. Send me your email address and I will share the data. I sold the car 3 years ago. It is still running track/AX events after 8 years and sounds great according to a friend who sees the car occasionally.
I'm just finishing up another 2.7 with 2.9 Mahle 9,2:1 pistons and 3.2 cams. Still with CIS. It feels stronger than the previous engine but no data yet.
Both have early sport mufflers (loud).
edsonconsta 07-21-2007 05:14 PM
Hi,
I'm interested would you please send me the dyno results of the engine.
Thanks a lot.
safe 07-22-2007 07:42 AM
Can't you post the dyno result, if you have it in excel just take a screen shoot.
