mnmasotto's Avatar
Cams with 3.2- 3.4L build-up?
I have a 87 motronic 3.2 which I plan on rebuilding. I live in california therefore I must remain CA Smog legal.
I plan to go with EBS racing for the 3.4L kit. They will bore out my stock Mahle cylinder to 3.4L and match a set JE pistons. I plan to keep the compression ratio no more than 9.5:1. I want to keep a single plug setup. I will leave the bottom end stock. Also, will replace cylinder studs and rod bolts.
What cam profile is recommended for a daily driver, CA smog legal with Cat legal exhaust systyem?
Also, anyone with experience boring out mahle cylinders to 3.4L then using JE pistons.
P.S. I have already looked into 3.6 transplant. It will not work well for my situation
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes
2006 M3 Competition Package
2007 997 GT3 - SOLD
Old 07-19-2007, 08:17 PM
Steve W's Avatar
Consider some 20/21 cams. They should smog and still makes lots of power.
Old 07-19-2007, 09:20 PM
