-   -   Divilar Studs on a 911 2.7 MY1977 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/358820-divilar-studs-911-2-7-my1977.html)
HKZ Bob 07-25-2007 11:10 AM
Hello folks,
what was the original head bolt setup on a 1977 2.7 7R case.
12 piece 911 101 172 00 upper studs
12 piece 930 101 170 00 lower divilar studs
Who can confirm this data out of the PET.
Regards
bob
MBEngineering 07-25-2007 01:58 PM
HI try hear
http://www.pelicanparts.com/PartsLookup/HTML/911_USA_74_77_KATALOG/101-05-Frame3.htm
Pelican has it covered with there PET system
regards mike
Steve@Rennsport 07-25-2007 02:49 PM
Bob:
2.7's (and prior) all had plain steel studs, top & bottom.
Its a VERY durable setup as long as the case has been properly prepared and you keep strict control of oil temperatures
Eagledriver 07-25-2007 05:24 PM
According to Bruce Anderson's 911 performance handbook the 77 engines had dilivar lower studs. This was the first year for these.
-Andy
HKZ Bob 07-26-2007 01:04 PM
Steve & Andy how can I figure out if I have divilar studs in my case ore not ?
MBEngineering 07-26-2007 01:40 PM
HI use a magnet on the studs , steel yes, dilivar no, after market no/maybe.
regards mike
