964 - Remove Pulley or Studs??
Forgot to put the engine mount bracket on before installing the pulley.
I was thinking about removing a couple of the studs that the mounting bracket goes over instead of removing the pulley, which is a pain.
Also, I noticed the manual talks about cleaning the crank with freon before installing the pulley. Is that to get it cold or clean the surface? Is there any shrinkage needed to get the pulley on right?
Thanks!
'89 Carrera 4
Old 08-05-2007, 08:22 PM
removing the studs works if i remember right.
206 637 4071
Old 08-05-2007, 09:46 PM
kirkf's Avatar
Easier to remove the pulley. IMHO.
Kirk
1989 911 Carrera 4 (964)
Old 08-06-2007, 08:18 PM
