-   -   header size (http://forums.pelicanparts.com/911-engine-rebuilding-forum/360459-header-size.html)
rbutts 08-04-2007 12:43 PM
header size
Im trying to find out what size header to use 4 my 3.2 short stroke which will have 46mm PMO's soon. I wanna use the type of headers that will connect directly to a 2-in 2-out sport muffler.:confused:
I've been told by two different sources 1 5/8 inside diameter and 1 1/2 inside diameter. Hoping some of the experts could straighten me out on this one.
Steve@Rennsport 08-04-2007 11:14 PM
What cams are you going to use?
That determines RPM range and thusly, optimal header diameter,..:)
rbutts 08-05-2007 01:28 PM
header size
I,m sticking with 964 cams for now. Also I have 79 heads & J&E 9.5 pistons.
