Still, the welds holding the heat exchanger to the headers seems to be a weak spot. Hope this will hold up to the task, there is a great weight advantage running this setup. |
I think the welds broke because of the lean conditions causing some serious expansion/contraction issues in relation to the heater boxes. |
The welder claims that one of the holes (don't ask me how he "concluded" that) is due to a weld going all the way "through" the header metal (not sure I'm explaining the way he explained it to me and what implications this has). He says in general the welds are good, more of a quality control issue, oh well. My AFR is a bit lean I give em that and I don't want to be reborn as a header on a car running the long uphill straights at the Nürburgring, the conditions doesn't get much worse... Hope to have my car running tonight, with a bit of luck I will spend the weekend on the race track SmileWavy |
http://forums.pelicanparts.com/uploa...1190935997.jpg
Got to love this sticker. http://forums.pelicanparts.com/uploa...1190935933.jpg Got everything together and started up the car. Engine sound is 100% and the car is as fast as ever :) http://forums.pelicanparts.com/uploa...1190936325.jpg A strange thing though, the car seems to pull as hard as ever and spool up is fast, still the boost pressure is lower than before using the same boost control setting and the boost pressure isn't going crazy at 2nd and 3rd gear as it did before. Looking at the picture above, this is the pressure hose between manifold and my boost control, it was dented at one place but most probably not leaking. http://forums.pelicanparts.com/uploa...1190936461.jpg I fixed the dented pressure hose with a 2 way connection (see picture above). Why is my boost pressure lower now with the same boost control setting. Would a dented hose show a higher boost pressure, wouldn't it be the other way around, could I have a leak now? Anyway, the car is as fast as ever, engine sound perfect. Will check the rocker arm shafts for movemnt tomorrow. |
http://forums.pelicanparts.com/uploa...1191252476.jpg
Just got back from a track weekend, the engine sounds and runs really well. No mechanical sound, just pure deep exhaust sound. Checked the upper rocker arm shafts before leaving, they where fine. http://forums.pelicanparts.com/uploa...1191252803.jpg The welds and header gaskets seems to have stood up to the task. Thanks everyone for helping me out! Since my engine seems fine I have developed a gear box sound, a mechanic that has driven the car says he is pretty much convinced it's a bearing in the gearbox going bad. Any hints on good resources for a gearbox rebuild ? |
Go for it! The Cayenne S is really a great vehicle.
Back to our regularly scheduled programming...... |
| All times are GMT -8. The time now is 10:11 PM. |
