-   -   Jetting advice needed please! (http://forums.pelicanparts.com/911-engine-rebuilding-forum/361920-jetting-advice-needed-please.html)
wejjy 08-14-2007 06:28 AM
Im about to purchase some jets for my fresh motor but not sure where to start?
The spec is as follows:
3.0sc 1980 (204Bhp)
MSD System
10.2:1 comp
Ported and polished heads
Headers (deffo) with rsr silencer (I think)
98ron gas
Webber 40ida 3ci (3.5psi pressure/rebuilt)
SmileWavy
jpnovak 08-14-2007 07:14 AM
What cams? Where do you expect your peak HP and torque? What size ports in the heads?
wejjy 08-14-2007 07:33 AM
Stock cams the heads are standard port sizes both intake and exhaust, and as for peak power im not sure, prefer to keep it as low down the rev range as poss and to make it a pulling engine rather than a screamer!
Henry Schmidt 08-14-2007 05:11 PM
40MM Webers
36mm venturies
150 main jets
180 correctors
F16
55-60 idles
Jetting varies but this should get you started
wejjy 08-15-2007 01:41 AM
Fab thankyou!!!
