-   -   Calling all experts!! Algorithm for 2.7L race motor to attain 300HP?? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/361979-calling-all-experts-algorithm-2-7l-race-motor-attain-300hp.html)
speed4sport 08-14-2007 03:11 PM
OK, I've jumped out of big bore Corvettes into a 911 'cause I've always wanted to and it will make me a better racer. Here is my baseline assumption - GTU (SVRA & HSR) class "magic" competitive number is 300HP.
Here's the engine I am currently running:
* '77 2.7L, stock crank & rods
* RS p&c's, ~9:1 CR
* Nice head porting / flowed, single plug
* S cams
* Weber 40IDA's, venturis & intakes opened to 38mm
* MSD 6AL ignition
* Race headers 1.625" primaries into 2" collectors
* 110 octane race fuel only
* Dynoed at ~240HP peak at 6900RPM
So what do you recommend for a next move? All of the below or a la carte???
* Big bore kit to 2.8 or 2.9?
* CR bump to 10:1?
* PMO carbs - 46/50?
* Different cams?
* Twin plug?
* Abandon 2.7 platform and start over with '78-'83 3.0?
* Other?
Obviously each decision has a cost versus benefit, and until I win the lottery, decisions must be prioritized. So need some help so I can stay ahead of the Nissans and Mazdas!
Thanks in advance...http://forums.pelicanparts.com/uploa...1187129456.jpg
Henry Schmidt 08-14-2007 04:54 PM
To see 300 hp with a 2.7/2.8 you will have to make hp all the way to 8000 rpm and beyond.
The 2.7 crank will not survive at those RPMs for long.
The mag case will also offer some challenges.
It's best to start with a 3.0 and build from there. Stronger crank, better heads and the aluminum case make the 3.0 the core of choice.
Even with a 3.0 platform, 300 hp is no easy task.
Ports
cams
compression
46 PMOs or more
Think RPM and start shoveling out the cash.
This 3.0 engine had all the goodies and only made a little over 280hp.
http://forums.pelicanparts.com/uploa...1187135535.jpg
kenikh 08-14-2007 08:16 PM
C'mon Henry, tell him about the short stroke 2.8! :D
shbop 08-14-2007 09:18 PM
And, another photo wouldn't hurt either.
speed4sport 08-15-2007 04:15 AM
Henry, thanks for the feedback. Your engine is a thing of beauty. I may shift gears and live with the 240hp, and put the car on a diet, stuff more tire under it, put an LSD in, etc....and buy a lottery ticket today.
Thanks!
speed4sport 08-15-2007 05:19 AM
Henry, just read the thread on your SS 2.8L. Nicely done - I definitely think your idea of putting together the ultimate and keeping it "old school" is just cool. Hmmmm, I have a survivor '77 930 sitting in the shop....
ael911 08-15-2007 09:08 AM
Sorry to hijack this thread a bit, but Henry, is there a way to build a short stroke 2.8 without using a 3.0 carrera or turbo case? I have been searching for awhile for one of those and it's virtually non-existent out there. Also, what kind of possibilites do I have if I use a 7R case with a 66mm counter crank?
Thanks,
Andy
Henry Schmidt 08-15-2007 10:18 AM
Pictures? You want pictures? You can't handle these pictures!
oops, channelling Jack again:)
http://forums.pelicanparts.com/uploa...1187198000.jpg
http://forums.pelicanparts.com/uploa...1187198043.jpg
http://forums.pelicanparts.com/uploa...1187198074.jpg
http://forums.pelicanparts.com/uploa...1187198163.jpg
http://forums.pelicanparts.com/uploa...1187198207.jpg
Henry Schmidt 08-15-2007 10:37 AM
Thanks,
Andy
There are two ways to build a 2.8 SS without a 3.0 Carrera or 3.0 Turbo case.
First, find a 66 mm 962 crank. They are out there and will generally cost around $2500.
The other option is to make a crank. That is what we are doing. They also cost around $3000. The benefit of making a crank is better material, improved oiling and of course they are new.
With a mag case 2.7 you can build a 2.5 (66x90) or a 2.6 (66x92) and have a very nice little engine but life expectancy of any mag case engine is reduced when high RPMs are encountered.
High RPMs is the reasoning behind short stroke engines.
ael911 08-15-2007 12:47 PM
So it looks like I will have to spend at least $3k either way for a donor turbo or carrera engine or buy the appropriate crank. I do like the idea of the new crank though. Thanks Henry, and keep us posted on your new developments.
shbop 08-15-2007 01:14 PM
Well, you're right. That just cost me about a half hour of unproductive daydreaming. On second thought, maybe not unproductive. Thanks Henry!
kenikh 08-15-2007 01:23 PM
One positive for new cranks is you can spec the journals for modern NASCAR type bearings. Of course then you need custom rods. :D Good stuff.
dd74 08-15-2007 02:35 PM
Originally Posted by Henry Schmidt (Post 3428051)
...but life expectancy of any mag case engine is reduced when high RPMs are encountered.
About what RPM would that be, where it is high enough reduce life expectancy?
ael911 08-15-2007 03:48 PM
That's a good question, maybe I shouldn't rule out making a short stroke out of my 2.7 just yet. Help us out Henry...
Henry Schmidt 08-15-2007 03:48 PM
There are so many factors that effect longevity, but as a 70.4mm stroke I would say sustained 7400-7600 would create a problem.
66mm stroke would live closer to 8000.
Reciprocating weight will play a huge role in longevity at higher RPMs.
Ti rods (light weight)
Lightened pistons
Counter weights
Shuffle pins
Controlled harmonics
All play a tremendous role.
dd74 08-15-2007 04:17 PM
Lightened pistons
Counter weights
Shuffle pins
So with a standard mag 2.7 case, sustained 7400-7600 begins to effect longevity. However, lightweight pistons, such as JE might mitigate some of the damage of such high revs?
Oh, and as always, thanks Henry for the help.
ael911 08-15-2007 09:12 PM
So Henry, I can build a 7R, 66mm crank motor with all the goodies you mentioned and expect decent life out of it if I keep it under 8K rpms?
Thanks for all your expertise.SmileWavy
dd74 08-20-2007 02:34 PM
Henry - any input into this question?
BTW: sent you a couple PMs.
Thanks.
SmileWavy
cstreit 08-20-2007 03:13 PM
Algorithm for 111HP/liter? Here it is. $ + engine = 300 HP.
Seriously though, you'll have to turn a lot of revs for that.
HawgRyder 08-20-2007 03:26 PM
And here I am rebuilding my 2.0L "S" with perhaps 90mm barrels, using an aluminum case and very large oil pump (got it off Ebay about 4 yrs ago).
The original idea was to build something with less compression so I could use lower octane gas.
I have been told, if I just use the 90mm barrels, without decking the cylinders or the heads, I will drop about 1 1/2 points on the C/R.
I have looked at the sets of 90mm barrels, and I notice that they have a groove at the top for a sealing ring?? perhaps.
Henry..can I use my S heads on these barrels...or am I now looking for heads as well?
Bob
