CASE Savers Installation homemade
I like to do my case saver installation at home, so I have some questions before I start.
I will use my box colum drill & have it centered over the original stud. For an thread of M14x2 I need a blind hole of 11,4 mm. I am not intending to use a drill or a milling cutter. I would like to use a broach or reamer to widening the bore to keeo it in center. Once the bore is available I am intending to use a three stage tap which I will insert into the drill ckuck to have it align propperly. Any comments or suggestions. Thanks for good advices. Bob http://forums.pelicanparts.com/uploa...1187865261.jpg |
| All times are GMT -8. The time now is 09:39 AM. |
