Engine rebuild suggestions
Hello from a Porsche novice. I have a 1968 Porsche Targa project car. I want to get a rebuild on the engine. I don't have the time to do this myself. I need suggestions. Should I change to a newer model engine? I want to add A/C and cruise. Don't care about a big power increase (some increase would be good). I was told to try MM for the rebuild but reading the threads here I get the idea that would be a mistake. Why? I appreciate any suggestions.
Thanks Tom |
Skunk works
hi tom
from what i've heard you should steer clear of MM having just had an engine built i know there are so many options to ponder 2 main points to consider are your budget and the primary use for the car ??? personally, my car is used 90% street and 10% DE so i opted to go for the torque of a later model & bigger displacement engine rather than having the 2.7 rebuilt if you are planning on racing certain classes may have restrictions on mods and displacement porsche aircon has never been very effective and aftermarket systems can cost big $ there are some very knowlegdeable guys on here good luck JV
964 RS-4 |
Tom, welcome to the forum.
What is the VIN of your '68? What model? The advice you receive is absolutely a function of what you have and what you want to do with it. In general, a '68 Targa is not the best platform for anything other than a restoration project, if the car can be brought back. The reason is that the highest value of a '68 anything is in original, unrestored condition, and if the car's unrestorable, there are better platforms on which to build performance. If one were to replace the engine then the brakes need to be upgraded, then the suspension and so on . . . pretty soon the car ends up looking like a 911SC, but without the galvanized body and chassis rigidity and flared fenders, etc. So, my answer is, if the car's in good shape, you should consider rebuilding the engine to original, or original-appearing, specifications. If you post your geographic location I'm sure you will get many recommendations as to good rebuilders in your area that can help with this project. Many of them are regulars here. Good luck!
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Constitutional Liberal
You couldn't do better than Supertec to rebuild your engine no matter where you live.
They rebuild engines for clients all over the world. They built my engine 4 years ago and I couldn't be happier. Read this, it was posted recently by Henry. Quote:
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Wow. I greatly appreciate your responses. I'm getting an education. I'll get that VIN posted. The car is a 1968 Porsche 911 Targa, with Weber carbs. I'm in Fresno, Ca. (an irrigated desert). A/C here is a must unless you don't want to use your vehicle from May to Sept. My expected use of this car not as a daily driver but as a frequent driver. I'll drive it to work occasionally, to the coast/mountains occasionally. I'd like it to be practical, perhaps drive it about half time. I'm fine with the 1968 look. I've seen a couple of these restored and expect that the only updates I'll want to do will be the A/C and shoulder/lap style seat belts. I may replace the sport seats. Other minor mods. The body is good (some body work and paint needed). The Interior needs restoration. I plan on doing most of the body and interior myself. I'm sure that I'll run into things I haven't thought of. I hope my budget works out. I thought I could do all of this for about 15 grand. Let me know if that is unrealistic. I don't think spending much more than that makes sense on this car. I figured that most of the cost would be the engine rebuild.
I was advised by a Los Angeles supplier of used parts (and engines) that the engine in a 1968 wasn't worth spending money on. Since I'm just wanting a reliable use car, I'm curious if you guys have that same opinion or if you think that It is OK to do. I'll check on that Supertec recommendation. Thanks again. Tom |
Skunk works
hey,
do-able but will depend on how much of the engine your you can do yourself and if your engine is within spec...if you: are doing a standard rebuild; dont need new pistons & cylinders; and can do everything except the machine work youself, then it'll cost $8-$10k if you arent doing the engine yourself, if you need new pistons & cylinders and if you want any performance mods things start to add up to $20k quickly.
964 RS-4 |
