can I use EMPI 4011 Case Saver, 10mm ID X 1/2 " OD as well
Hello
I would like to know if I can use EMPI 4011 Case Saver, 10mm ID X 1/2 " OD instead of the OD M14x2 I wonder why I canīt stay with 1/2" OD instead are going to M14. I M14 pulls out. My case ist dead. CASE SAVER INSERTS Repair stripped and worn head stud threads. Case savers provide greater hold. Each kit has 8 inserts. http://forums.pelicanparts.com/uploa...1188150548.jpg EMPI 4011 Case Saver, 10mm ID X 1/2 " OD, Set of 8 [/B] Bob |
Just my .02 cents empi of today isn't the same as the good old day's I wouldn't use there products on a VW motor I definitely wouldn't use them a 911 engine.....
I bet the 1/2" is a fine thread and thats what you don't want..
| All times are GMT -8. The time now is 06:02 AM. |
