304065's Avatar
Updated idler arms don't fit with 930 tensioners
Here's a new one I think-- when updating a more modern car folks often need to use an aluminum spacer on the idler arm shaft in order to position the tensioner in the right place.
I think I have the opposite problem-- I have the new, wider, double-bushing idler arms, and when I try to fit them on the shafts of my '66, the 930 tensioner doesn't fit correctly. This is, I assume, due to the additional thickness of the idler arm.
Has anyone else faced this problem? I assume the solution is to revert back to the original idler arms with the 930 tensioners. Obviously Carrera tensioners are not an option, because I have to maintain an original appearance.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-01-2007, 10:23 AM
either go with new original style tensioners that have the thinner end or thin yours out to fit.
206 637 4071
Old 09-01-2007, 11:24 AM
304065's Avatar
Thanks John. What should I cut? The aluminum or the bronze?
'81 R65
Old 09-01-2007, 12:42 PM
Cut the aluminum.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-01-2007, 12:45 PM
304065's Avatar
West Coast in the house! Thanks Gentlemen!
'81 R65
Old 09-01-2007, 12:53 PM
304065's Avatar
I see where to cut.
'81 R65
Old 09-01-2007, 04:50 PM
HarryD's Avatar
John,
I have some older arms if you want them. I wish I knew you might need them when I sent you the oil lines.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-02-2007, 07:38 PM
304065's Avatar
Harry,
I appreciate that nice offer. I'm actually going to stick with the new idler arms and order some brand-spanking-new tensioners. As posted by Warren Hall a/k/a "Early_S_Man" a while back, in order to make the tensioner fit you have to remove 10mm from the mounting boss. But to do so requires that you cut through not only the boss but a supporting rib.
Not having (yet) a Bridgeport in my garage I'm going to offer the old tensioners for sale and hold on to my rebuild kits for the future. Nor do I wish to risk the whole project on my own engineering skillz. . . .
'81 R65
Old 09-03-2007, 06:01 AM
