-   -   New engine first run... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/365116-new-engine-first-run.html)
speedo 09-02-2007 03:52 PM
Followed all the prerequisite rules. Started the 2.2 race engine for the first time, and was surprised that I had literally no smoke. Every other rebuild that I have been involved in...smoked like hell during the 20 minute run-in.
I had good oil pressure, and no leaks(that I see yet).
I thought the rings were going to smell as they settled in and the engine would blow smoke for a while??:confused:
Speedo
Eagledriver 09-03-2007 05:16 PM
You only get lots of smoke if you have used lots of oil on the rings when you put the engine together. Modern procedure is to use a very light coat of oil on the rings so they seat quickly. I used WD-40 as per the recommendation with my new rings, plus some motor oil on the piston skirts.
-Andy
weare138 09-03-2007 05:30 PM
I'm in the process of breaking in my 3.2ss and I also had no noticable smoke. I used motor oil on the rings and then wiped away the excees after installing the p&c.
JeremyD 09-11-2007 01:04 PM
+1 = very little smoke - I was suprised.
