Fuel delivery
Dose anyone know the fuel delivery rate for the standard 3.0L SC
CIS fuel pump in leters or gallons per hour? I think my engine is leaning out at the top end. I have installed an inline Holly regulator with by-pass to keep below 9 psi fpr carb, maybe I will have to go to a low press, hi volume pump.
Old 05-01-2008, 05:53 AM
How do I troubleshoot the fuel pump?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-06-2008, 09:47 PM
.85 liters / 30 seconds . . . checked by the return fuel hose. pm me if you need more info. going out of town till next thurs . . . so may take a couple days to respond.
Old 05-07-2008, 12:50 AM
Thanks guys, should be enough, around 100 lph will take a look at my jetting.
Old 05-07-2008, 06:19 AM
seems like you're using the dead head regulator?
how did you plumb a Bosch rotary cell SC fuel pump & the regulator?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-07-2008, 07:15 AM
Have switched regulator since pic but just to show location.
Old 05-19-2008, 04:51 AM
Wer bremst verliert
JohnJL's Avatar
Not sure which carbs but you should be around 5psi.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 05-19-2008, 05:44 AM
