Do grooves in thrust bearing matter?
There's an old article in Velocity, the POC magazine, by Gregory Brown, that claims that if you get your thrust bearing from Glyco, the aftermarket supplier, it has different grooves than if you get it from Porsche.
![]() He claims: Quote:
Now, here's what PET shows. The grooves look pretty big to me, much like what's in my Glyco set. ![]() Thoughts? Important or no?
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) Last edited by 304065; 09-16-2007 at 04:15 PM.. |
John: I saw the reply you had to my thread, that you must've deleted to start this thread. To answer your question, I've seen that article, but I also have the Glyco bearings with the large groove.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
The only significant effect I could see is how much oil gets to the thrust surfaces of the bearing. The notches that don't go all the way through will cause more oil to get onto the thrust surfaces. The loss of pressure in the crankshaft galleys will be insignificant. The oil pressure is mostly contained by the tolerance of the bearing on the crankshaft journals. Think about the other end of the crankshaft. The number 1 bearing that feeds that end of the crankshaft has no thrust surfaces to contain the oil there. The thrust surfaces of the number 8 bearing don't seem to be a problem area of the engine so I think this bearing difference is irrelevent.
-Andy
72 Carrera RS replica, Spec 911 racer |
Andy, I think you have your numbers backwards....
FWIW,....We do not use aftermarket Glyco bearings,............its a dimensional QC issue.
The ONLY bearings we will use are either dealer-sourced main & rod bearings or specially-made ones due to FAR better concentricity and overall dimension control.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Steve, I understand, it's all about the dementia, er-- dimensions.
Well, I have a ball tip for my micrometer, basically a sphere of radius smaller than the bearing's radius, that I can use to measure the thickness at various spots, including the taper at the ends. As far as surface finish goes, any irregularities will be noted. It's interesting that so many professional engine builders have noted the poor QC of the Glyco bearings. A well-known expert here on the East Coast who shall remain anonymous but whose initials are Peter Dawe said he prefers to use a NASCAR bearing due to the high quality coming out of North Carolina. Here's a reference to a good thread on the subject for anyone interested. Glyco bearing quality
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
