GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Cylinder Head Gasket Orientation ? flat/round
Ive pulled away my Heads from the cylinders tonight on my 2.4 because of a couple of Leaks coming between them.
I noticed that the a couple of Springs on the Cylinder Head Gasket (that sit on Top of the Cyliynders) had busted apart. The springs were completely apart and oil bypassing
What would cause this, ?
I also noticed on the New ones that these have a Flat side and a Round side
What is the Correct Orientation for Assembly?
Flat Side Down on the Cylinder ? ? ? (im guessing)
Old 09-17-2007, 06:06 PM
GotaT's Avatar
Bump.. Anyone know the orientation and such.. ? ?
Old 09-18-2007, 01:47 PM
304065's Avatar
It is not necessary to keep bumping your thread to the top of the page when it is only five or six threads down from the top.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-18-2007, 02:23 PM
sww914's Avatar
I do it the way that you described and I haven't had any problems.
Keep in mind that I've built dozens of engines, not hundreds or thousands like some of the guys around here.
Old 09-18-2007, 03:21 PM
Less brakes, more gas!
euro911sc's Avatar
My guess, and it is a guess, would be flat side up against the head. I used to design similar metalic seals, but they were always symmetrical so it did not matter which way they were placed in the receiving channel. I say flat side up as that would be the leading edge and you may wish to have more sealing surface there, but I suspect it may not matter... Was there no spec sheet in the box?
I'll be interested to here the experts chime in.
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 09-18-2007, 03:22 PM
