The Complete Case Assembly Procedure Thread
OK, to go with the Complete Sealant Thread, http://forums.pelicanparts.com/911-engine-rebuilding-forum/284737-complete-engine-sealant-thread.html , and the recent comments on the importance of "rehearsing" this, I thought I'd do a step-by-step checklist for the steps involved, and the order I'll do them. What do you think?
Case Assembly Sequence Final Prep: Lube oil pump internals Oil seals lubed, installed in case & pump Lube layshaft bearings Timing chains on shaft Oil pump/layshaft lubed journals, installed LH timing chain supported Oil pump bolts Mark order of thru-bolts Torque wrench set at 25 ft-lbs, proper socket, box end wrench Rear seal lubed and ready Lube/Install nose bearing on crank Washers, nuts (perimeter and thru bolts), o-rings handy Lube main bearings Install crank Check backlash on Layshaft gear 1, 2 & 3 rods supported 1211 spread thin on #8 saddle RH and LH halves 1104 lay out bead and spread thin around LH case perimeter 574 rolled on bearing saddles Dow 55 ready for o-rings Assy: Place LH case on RH side, tap lightly with mallet Tap in rear main seal Install & torque and lube o-rings (Dow 55), washers and nuts @ oil cooler 25 ft-lbs Install & torque nut in LH timing chain housing 25 ft-lbs Install nuts around perimeter Install & torque and lube thru-bolts/o-rings (Dow 55) 25 ft-lbs Check that cranks spins freely Torque perimeter (2 reverse) and 3 flywheel housing nuts 18 ft-lbs Sit back with several beers and ogle :D ,allow to dry overnight |
How about first step under assembly - "Get a friend."?
It is SOOO much easier with an extra set of hands. ;) |
Ed, a few proposed revisions below
Verify dowel pin in place for number eight bearing Preinstall number eight bearing and mark a line along the case with a sharpie so you can correctly reinstall on the pin Lightly lube oil pump internals and loctite nuts Oil seal in RIGHT case half Install intermediate shaft bearings Dry-fit oil pump, connecting shaft and intermediate shaft, check for free rotation If no free rotation, reposition connecting shaft on different splines until it spins Mark correct position of connecting shaft with sharpie Remove oil pump, connecting shaft and intermediate shaft and lubricate bearings Loop timing chains around intermediate shaft and dangle through chainbox hole Install oil pump, connecting shaft and intermediate shaft Lubricate main bearings with assembly lube Install pulley seal in number eight bearing Install o-ring on number eight bearing and lube with Dow Corning 111 Lubricate pulley end of crankshaft with assembly lube and install into number eight bearing Apply 1211 to bottom side of number eight main bearing saddle, avoid oil hole Install crankshaft in case Install oil pump tabs and lock nuts 900 076 025 02 and torque to 25NM- do not bend tabs yet Verify intermediate shaft backlash with dial indicator Bend oil pump tabs Install connecting rod and chain props P221 and P222 Install TWO oil pump seals 999 704 172 50 Preassemble case through-bolts with O-rings and DC 111, do not tear o-rings Mark order of thru-bolts with lead pencil so it comes off easily Set torque wrench to 35 NM Now, a couple observations. First, you're doing it the factory way with the oil pump first vs. Wayne's method of crank first, it really depends on how many hands you have. Second, I recommend torquing the through-bolts first because you want to establish the bearing clearance right away, particularly if you are using 574 on the bearing webs. 1104 lay out bead and spread thin around LH case perimeter, avoid oil relief! 574 rolled on bearing webs on left half Assy: Place LH case on RH side, tap lightly with mallet Install through bolts with nuts on LEFT case half (same as perimeter nuts) Torque through bolts to 35NM (25.8 ft-lb) Torque additional case studs (timing chain housing, case side) and nuts in oil cooler flange RESET TORQUE WRENCH TO 25NM (18.4 ft-lb) Install case perimeter washers Install case perimeter nuts Torque ALL case perimeter nuts incl. flywheel and reverse to 25NM Check that crank spins freely Well, I'm outta gas for now, double-check all that and make sure I didn't leave anything out! |
man, I came to the right place!! Thanks
I was trying to do a simple "last minute" checklist here. I guess that's why others have written entire books, it is just too many things to do on one simple list? |
Different strokes for different folks-- I prefer a very detailed checklist so I don't have to go to four different sources (wayne, FWM, Little White Book, Parts Manual) to have all the information at hand.
That said I DID have an abbreviated pre-landing checklist on the door of my Citabria that said "Mix air trim pump lights brakes"-- to some, a checklist is ONLY those items you cannot forget before commiting, to others, it's a "do list" or flow pattern. A true "Check list" would be-- oil pump seals, timing chains, verify backlash, torque oil pump nuts and set lock tabs, preassmble throughbolts, set torque wrench, mark tightening order, avoid oil relief and check that the crank spins. Not specific instructions but only those things you absolutely must verify before moving on. |
I guess that with my list, assuming I've hit all the hot spots, one could copy & paste, and make whatever detailed notes they need for each one.
I'm thinking here how I do when I make a PowerPoint presentation; I know what I need to say, I use the program for bullet points to make sure I hit each necessary item in the proper order. |
How do you lube the oil pump?
Thanks |
Step
May have been there but didn't see it..
How about prep through bolts? You can get them set with washers and rings lubed and ready to insert / install. Gordo |
Dont forget to put the separator tins in before the oil return tubes and heads.
Bruce |
| All times are GMT -8. The time now is 01:50 PM. |
