-   -   Funny object on chain Tensioner (http://forums.pelicanparts.com/911-engine-rebuilding-forum/368212-funny-object-chain-tensioner.html)
hbrand 09-21-2007 11:07 AM
Look what I just found mounted on the chain tensioner:
http://forums.pelicanparts.com/uploa...1190397946.jpg
It funnels the oil to that screw on the tensioner.
Boy, if this falls off - thats it for the engine.
harold
cgarr 09-21-2007 11:19 AM
Whats all that white stuff on your chain?
hbrand 09-21-2007 12:45 PM
The white stuff is assembly lube. I got this engine in a rolling empty early targa - terminated restoration project. The engine had been rebuild, never run, never timed, just money thrown on it without brains. I do not know who did the work.
The targa tub is about rust free after someone did a lot of welding.
When I examined the engine I found the funnels on the chain tensioner's.
Harold
cgarr 09-21-2007 12:59 PM
It looked like White Lithium Grease which is bad if it is, it does not mix well with oil, but if its assembly lube it should be ok
Mo_Gearhead 09-24-2007 12:39 PM
Ok ...I'm rather slow on the uptake. What possible purpose would those pieces serve? How are they even attached to the engine? It's not like there is a large flow of oil there that they are 'catching' to aid lubricating something???
Confused here????
